CHIPS CHIPS CHIPS
Old Jul 2, 2001 | 06:58 AM
tonytt225's Avatar
New Member
Default CHIPS CHIPS CHIPS
I am considering installing a chip, could anyone tell me;
1. WHICH ONE IS THE "BEST"? Why?
2. Would YOU use it? / do you have it?
3. Can it be 100% concealed from the dealership when I bring it in
for service?
4. How much damage does it do to your engine?
5. Is it worth it?
Old Jul 2, 2001 | 07:13 AM
JustJeff's Avatar
PEPSI PEPSI PEPSI
Old Jul 2, 2001 | 07:37 AM
dallasTTQR's Avatar
Junior Member
Default Re: 225R
1. Everyone will tell you the one they have is the best.
2. ABT great power from 2800 to 6500.
3. I have the ABT
4. None of them can be 100% concealed if the dealer opens the ECU. Buy the extra ECU with a chip that's 100% concealed
5. It's worth it. One can only guess if any of the chips will damage the engine. Not enough time in cars to determine
Old Jul 2, 2001 | 07:44 AM
tonytt225's Avatar
New Member
Default Re: 225R
Does the chip improve the "low end" initial acceleration that the tt's suffer from? Also, how much does it cost generally?
Old Jul 2, 2001 | 07:52 AM
JustJeff's Avatar
Default Since I initially gave you a smart-a$$ answer....
I have the APR, and it will boost the low end also, but it seems you either have to wait for the initial turbo-lag, which is present before you chip, or slip the clutch a bit to bring it full on-line.
If you wait for the inherent turbo lag, you will get a rocket-start from a 'chip', second gear comes very fast.
If you slip the clutch a bit you will smooth out that start, but it will come on very fast, the fastest start I have done is this method, thou I don't advise this very often, for obvious reasons.
The chip prices vary from like $300 to $600 +, something like $1400 with a spare ECU.
Old Jul 2, 2001 | 08:03 AM
dallasTTQR's Avatar
Junior Member
Default Re: 225R
I would have to say from idle to 2500 rpm the car feels stock but after that you will feel the increased boost. I can't say if any other chips improve below that rpm range. but I am happy with my purchase (ECU + chip) $1400. German chips (MTM & ABT) are $695. American chips (Garrett, APR, ETC) are cheaper around $500
Old Jul 2, 2001 | 08:08 AM
tonytt225's Avatar
New Member
Default Re: 225R
The damn ABT site is German aaaaaaand I am not, soooo is there a site where I can do the research on this? Or better yet, I'm sure you guys did your research before purchasing your chip(hopefully)...could you point me to a good site?
Old Jul 2, 2001 | 08:20 AM
dallasTTQR's Avatar
Junior Member
Default Re: 225R
www.stratmosphere.com/abt_tt_engine_performance.htm
www.goapr.com
 Pouria Savadkouei
 Michael S. Palmer
Old Jul 2, 2001 | 08:28 AM
john s's Avatar
Member
Default No change below 2200 rpm.
ECU controls damage based on engine knock (needs to hear knock before correction can be made) and exhaust temperature. Under high power, exhaust temperature could exceed 1000°C. Controller adds more fuel (richer than stoichiometric) to maintain temperature at 980°C.
RallyAudi
Jun 22, 2011 05:30 PM
Jamin
13
Jul 12, 2003 02:32 PM
tt669tt
Jun 4, 2003 05:53 PM
silva41.8T
18
Apr 3, 2003 06:29 AM
Riccardo
Jul 29, 2001 05:27 AM
