OT: need a suggestion for perhaps a wrench..
Old Jul 2, 2001 | 07:09 AM
Ego's Avatar
Ego
Junior Member
Default OT: need a suggestion for perhaps a wrench..
Greetings,
I have an issue -- I have been doing some restoration work on my 944, and started to work on the exhaust. I came to find that the nuts holding the catalytic converter to the manifold had two sets of pipes, 4 nuts/bolts each. Of those 8 nuts, 5 of them were rounded off, but not entirely. They still have some shape left, but I'm afraid to go at it with a pair of pliers, since the nuts are on so tight (up to 15 years of corrosion and such).
So, does anyone know of a tool that is made for getting rounded nuts off, but also allows for a great deal of torque to be applied? I remember seeing something on one of those TV advertisements, but can't remember what it was called or anything. Preferrably a socket-type deal would be best, since I can't really get a wrench up in there (too small of an area). Cutting the bolts is also not an option (due to the space restrictions in there), and drilling the bolts is also not an option.
I'm looking for any help you guys might be able to offer, rather than taking the thing to an exhaust shop. I fear that as an option.
Old Jul 2, 2001 | 07:18 AM
hoTTub's Avatar
Member
Default hhhhmmmm...I know you mentioned that cutting or drilling is not an option but...
I have seen a tool that will work in tight situations (I actually saw it at home depot) If you can get a wrench on he nut, then you could get this cutter in there
Old Jul 2, 2001 | 07:20 AM
JustJeff's Avatar
An old-fashioned vise grips, *do not* try one of those new-fangled mangelers!
Old Jul 2, 2001 | 07:22 AM
Ego's Avatar
Ego
Junior Member
Default Hm, I thought about that, but (more)
I couldn't get a pair of vice grips in there. There's just not enough room with the surrounding stuff in there to get a wrench of normal size in there. A socket works fine, but anything else is nearly impossible to fit in there, and once in, you can't turn it..
Old Jul 2, 2001 | 07:23 AM
RobbyTT's Avatar
Senior Member
Default The TV ad you're talking about is 'Robo-Grip' perhaps. Bob Villa swears by it...lol
You could probably get it from a Sears but I don't think it's going to do what you need. Whatever you try, make sure to soak those bolts in some good penetrating lube for a day to free up some of the rust and corrosion.
Old Jul 2, 2001 | 07:27 AM
Jim TT's Avatar
Default Oh man, it sounds like a war is about to start...
..I have had the same issues with other cars, and have had what could have been a 5 minute job turn into an 8 hour one. I wonder if you can drop the whole exhaust? I have found this to be helpful but it may not be an option on a 944. I had to cut the cat bolts off most of the time when they are rusted and rounded off; I know of the extractor socket you are talking about but can't recall who makes them. I'm sure you can win in the end if you are persistent and can take what ever time you need, and it sounds like you can.
ModifiedA4's Avatar
Banned
Probably a Dremel tool.
Old Jul 2, 2001 | 07:31 AM
JustJeff's Avatar
Default Cutting torch is the only answer...
A good guy will have them off in 10 mins.
You'll need new bolts anyway
 Pouria Savadkouei
 Michael S. Palmer
Old Jul 2, 2001 | 07:32 AM
hoTTub's Avatar
Member
Default lol....no it was almost like an closed wrench but....
it has a nut on the top
You put the *wrench* over the nut to be split and then tighten the nut on the *wrench*, this will start the spitting process
Did that make sense?
Old Jul 2, 2001 | 07:39 AM
Ego's Avatar
Ego
Junior Member
Default Yes, that's the beauty of this whole ordeal, I've got about
3 months to get this car to snuff, so time is not of urgency. If this were my daily driver, I would have already taken it to an exhaust shop to have them take care of the problem. I figured, since I have the time, why not take my time and save some money doing everything myself. In time, I'm sure I'll find a solution.
As a side-note, dropping the whole exhaust would be fruitless. Can't do it without getting the cat out first. I had thought about that at first (hey, why not just do the whole exhaust while I'm down here), but found very quickly that I'm stuck getting the cat off first.
Thanks for the input Jim!
