Bad Shock Syndrome (BSS) Help
This happened shortly after putting 18" Millia Miglia's on the car so I'm not sure if it's normal for the 18" wheel or if the shocks went south after the install. When we installed them the hydraulic jack was not let out "gently". Not surte if that could play a role or not.
Also, Should the tires pressures be set to the same as they would for the stock tires?
Thanks guys! (and gals)
Anyone have any ideas?
This is my personal experience; some here will vehemently disagree. Perhaps they drive on better maintained roads then I do. Admittedly, my car sees some lousy pavement and even gravel roads occasionally.
I had my 5000 mile service today. I noticed more this evening and I hadn't thought of mentioning it to the service guys.
