Block 115 questions?
Old Aug 15, 2001 | 05:14 AM
DevDocTT's Avatar
New Member
Default Block 115 questions?
Can anyone tell me what the values in Block 115 represent? I am also quite interested in what factors create the Load%(whatever that is). It appears that the higher the load, the higher the boost. I have compared two chips under consistant conditions, yielding quite different results. One drops boost over 5K quickly and the other does not.
Thanks in advance,
DevDocTT
Old Aug 15, 2001 | 08:54 AM
john s's Avatar
Member
Default Use 204 & 120
rpm,manifold press, cmd press, turbo press
rpm, torque limit, net torque, ASR status
Old Aug 15, 2001 | 08:59 AM
DevDocTT's Avatar
New Member
Default Re: Use 204 & 120
Should I log these simultaneously? Any idea on the Load% meaning?
Old Aug 15, 2001 | 05:17 PM
john s's Avatar
Member
Default Yes & it has to do with the fuel load, I have a note of it somewhere.
Percent of stroke or some such thing I'll look for it.
Old Aug 15, 2001 | 05:51 PM
DevDocTT's Avatar
New Member
Default Re: Yes & it has to do with the fuel load, I have a note of it somewhere.
Could that cause the ECU to reduce boost as well? I need a few more pieces of informtion to be able to diagnose what my car is doing.
Any help is appreciated.
Old Aug 15, 2001 | 06:53 PM
john s's Avatar
Member
Default Check blocks 20 & 112
20 has the timing corrections, the more retard the greater the exhaust temp, 112 has the exhaust temp reading for control. Range is 950 to 1030°C, if under-range temp pegged at 950°C. When it first gets on line it usually dips under 950. Fuel is added to hold exhaust at 980 if temp goes over. You can get more power reducing boost & increasing ignition timing and A/F ratio if things go to far. Block 120 will tell you. High boost & high flow also gives high inlet temps. Block 221 has throttle opening, ignition timing, coolant temp & intake temp, check this also. Only compare when 100% throttle opening.
The_Jerbel (Jordan)
May 26, 2007 07:13 PM
BOOSTD
Performance and Tuning
Sep 10, 2003 10:28 AM
nogaro*blue*you*away
14
Jun 1, 2003 02:15 PM
Singletrack
Jan 25, 2002 09:09 AM
blitz
Mar 1, 2001 07:59 AM
