APR Chip for 225 questions
Old Aug 15, 2001 | 05:20 AM
DevDocTT's Avatar
New Member
Default APR Chip for 225 questions
Has anyone compared the APR to the GIAC? I am looking at both and would love some input. I have tried another chip which had the boost drop over 5K RPM which I found unacceptable. Many people on the forum with this chip are looking in the wrong direction with this intake issue IMHO(backed up by a bit of testing). I will not mention the chip name until I have completely ruled out all possibilities(I hope you understand)
Any input would be appreciated,
DevDocTT
Old Aug 15, 2001 | 05:26 AM
Bluto's Avatar
Default Sorry, but my high rpm power drop is fixed...
<center><img src="http://pictureposter.audiworld.com/7612/intake7.jpg"></center><p>and it was fixed after I installed this intake. Yet to substantiate w/facts. But, butt dyno definately says there are improvements.
Old Aug 15, 2001 | 05:28 AM
SecuriTT's Avatar
Junior Member
So, do we have a consensus on the CDA box?
Old Aug 15, 2001 | 05:33 AM
hoTTub's Avatar
Member
I would consent but I have not received mine yet
Old Aug 15, 2001 | 05:37 AM
DevDocTT's Avatar
New Member
Default Re: Sorry, but my high rpm power drop is fixed...
Have you confirmed your boost levels? If possible check to see what levels you are getting pask 5KRPM(I did not mention the chip I had the problem with). What Intake sollution is that you are displaying?
Old Aug 15, 2001 | 06:47 AM
Rennen's Avatar
Elder Member
Default I'm not so sure the 5K> power drop is related so much to lowered...
...turbo boost as much as a rich A/F mixture. It seems that in chipped engines, the A/F turns very rich on the high end of the rev range resulting in a significant power drop-off. I think that's why some are speculating on intakes vs. other methods.
Old Aug 15, 2001 | 07:24 AM
Bluto's Avatar
Default Exactly, my A/F ratio was all screwed up IMO
physical evidence was the carbon builup on exhaust tips.
Old Aug 15, 2001 | 07:25 AM
Duffer's Avatar
Member
Can't compare - liked the APR EMCS and wanted to stick w/ 1 specialist to upgrade to APR Stg 3 1 day
 Pouria Savadkouei
 Michael S. Palmer
Old Aug 15, 2001 | 07:28 AM
Bluto's Avatar
Default A little update.
Spoke to ralf earlier this week, and he said that the will be replacing the crappy dryer vent hose with a much better insulated aluminum hose.
And, one other update that IMO will make this box a perfect fit. A hint, there will be no more issues w/using screw to connect intake w/the new filter.
Larry you reading this?
Old Aug 15, 2001 | 07:38 AM
Rennen's Avatar
Elder Member
Roberto. Does the snorkle solution provided work ok on the 225 w/o FMIC?
