Forge DV spring change innitial results
Stock DV
opens at 5'' Hg Fully 9'' Hg
Forge + Spring
Green opens 4'' Hg Fully 10'' Hg
Blue 8'' Opens 16.5 Fully
The point of all of this is that my TTR225(may not represent all) pulls 13.5'' Hg to the DV. After changing the spring from blue to green, it appears (Vag-Com confirms) that the turbo is having an easier time regaining boost after quick shifts. My estimation is that the fully opened valve under the lighter spring is opening quicker and more completely. Perhaps avoiding the partial turbo stall(I think this is correct) I experienced before the change under quick sequential shifts at high RPM(3-4-5). The green spring also appears to be closing just fine and holding plenty of boost(up to 1.4 Bar).
Food for thought,
DevDocTT
with Forge max vacuum held approx. 27"
max boost about the same approx. 9#
most noticeable is the differnce in transition from vaccuum to boost while accelerating
stock DV shows gradual smooth transition as though valve is closing slowly
Forge DV displays immediate step transition from vacuum to boost as though valve is "slamming" shut
