Build-up on battery terminal
Old Aug 16, 2001 | 05:02 AM
Bluto's Avatar
Default Build-up on battery terminal
Anyone else have this, I think Larry did. Any reason why. It looks like a calcification of on one of the terminals.
The engine has been cranking a little more on start up, and I think this is the reason.
Any recos on how to remove, the cause?
Thanks
Old Aug 16, 2001 | 05:09 AM
DavesTT's Avatar
New Member
Default Use a wire brush to remove the deposits. I think you can even get
battery terminal brushes. Im not sure why it happens, maybe moisture, its common on older batteries.
Old Aug 16, 2001 | 05:20 AM
RobbyTT's Avatar
Senior Member
Default Well - last time I saw your engine compartment (via intake posts) if looked like crap :)
Hose that sucker out and brush off the battery It was dusty
Old Aug 16, 2001 | 05:33 AM
Bluto's Avatar
Default damn...
I did clean it last weekend, after the original pics where taken!
Let's see yours then tough guy :-p
Old Aug 16, 2001 | 05:44 AM
RTinNYC(again)'s Avatar
Elder Member
Ewwwww!!! Clearly, the car must be replaced!!!
Old Aug 16, 2001 | 06:07 AM
RobbyTT's Avatar
Senior Member
Default I have no pictures of it at work but why not wipe it out with each wash?
It's like taking a shower and not washing your *******. Yeah most people won't take a look in there but you want it clean, right?
Old Aug 16, 2001 | 06:25 AM
OTOF's Avatar
Elder Member
eeeewwwww
Old Aug 16, 2001 | 06:39 AM
hoTTub's Avatar
Member
Totally Brutal and uncalled for >>>>>>>>>but very funny
 Pouria Savadkouei
 Michael S. Palmer
Old Aug 16, 2001 | 06:43 AM
hoTTub's Avatar
Member
Default Here is my serious recommendation on how to remove this build up >>>>
Seriously, take a can of Coca Cola, Pepsi what-eva and pour it onto the the terminals. You will see it fizz up and then use an old toothbrush or equivalent to get the *really* crusty stuff off, then rinse with a hose.
The soda counteracts the acid on the terminals and breaks it down
HTH
Old Aug 16, 2001 | 06:55 AM
Bluto's Avatar
Default NO MORE A$$ COMMENTS
but I do wipe down all my jams after each wash FWIW!
