Could someone tell me where I can get black front rings please? Thanks :)
Old Aug 16, 2001 | 10:42 AM
SwifTT's Avatar
Junior Member
Old Aug 16, 2001 | 10:56 AM
hoTTub's Avatar
Member
Default Home Depot :)
They are in the Blk Spray paint section
Seriously if you want the blk rings from a store, check with Stratmosphere, I think Abt sells them and they sell Abt <ul><li><a href="http://www.stratmosphere.com">http://www.stratmosphere.com</a</li></ul>
Old Aug 16, 2001 | 11:09 AM
SwifTT's Avatar
Junior Member
Can I really paint it myself?
Old Aug 16, 2001 | 11:15 AM
hoTTub's Avatar
Member
Default The one in my sig is only paint, Heres how >>>>>>>>>>
Need:
-Screwdriver or putty knife
-1000 grit sandpaper
-Primer
-Semi Gloss Bll SPary Paint
-Take a thin screwdriver or knife and gently pry the ring off the grill from one side.
-Take 1000 grit sandpaper and sand it <b>real</b> good all over the surface (even in the cracks and crevices)
-Spray with Primer
-Let dry
-Spray with Blk semi gloss
-Let dry
DONT use clear coat, it will look to shiny
Enjoy
Old Aug 16, 2001 | 11:20 AM
Paul DeFalco's Avatar
Bought mine from Advanced Motor Sports ($35.00). Painting OEM rings did work for me.
Old Aug 16, 2001 | 11:27 AM
SwifTT's Avatar
Junior Member
Cool.. new project Thanks!
Old Aug 16, 2001 | 11:40 AM
Duffer's Avatar
Member
Sean - how does one take off quattro badge on front and back?
Old Aug 16, 2001 | 11:46 AM
hoTTub's Avatar
Member
Default The front is clipped on as well, someone that *actually* took one off should chime in but....
for the rear badge,
I have found that dental floss worked back and forth behind the badge will make it come off easy.
Then use a prewax cleaner or Goof Off to remove residue
 Pouria Savadkouei
 Michael S. Palmer
Old Aug 16, 2001 | 11:49 AM
Duffer's Avatar
Member
Thanks, Sean
Old Aug 16, 2001 | 06:05 PM
axel's Avatar
Default Just two clips hold the front one on, your fingers can
pop them off. If uour fingers are to big a small screw driver will pop the clips off.
KamalS2000
11
Sep 12, 2005 09:59 PM
1 Mean TT
Apr 13, 2005 10:46 AM
djnelsen
Apr 30, 2002 04:38 PM
Jurgen
10
Mar 22, 2001 12:39 PM
Paul DeFalco
Jan 24, 2001 09:24 PM
