Shifter ring loose?
Old Aug 16, 2001 | 04:55 PM
MaesTTro's Avatar
New Member
Default Shifter ring loose?
Quick question: Is the brushed aluminum ring at the top of the shifter boot supposed to be loose on the shaft, or fit snugly to the bottom of the shifter ****?
Mine is somewhat loose, and I'm wondering if it's normal.
Old Aug 16, 2001 | 05:10 PM
225TTR's Avatar
Senior Member
Default You probably just need to tighten the screws (4 of the 8 are 'faux', so find the real ones....)
You need a torx driver. (If the driver turns, you've found one of the real screws. It's either 4 or 5 real ones.)
Old Aug 16, 2001 | 05:34 PM
TTom TTR's Avatar
Mine's not loose, but recently I feel like Raiders of the Lost Ark when I grab it on a hot day.
Old Aug 16, 2001 | 07:26 PM
case's Avatar
New Member
It should fit tight and be snug against the shift ****, mine was lose and was replaced by the dealer
Old Aug 16, 2001 | 08:24 PM
PorTTland's Avatar
Member
Default Now THAT is hot.
<center><img src="http://albums.photopoint.com/j/View?u=1427640&a=13582091&p=53032262"></center><p>
Old Aug 17, 2001 | 04:07 AM
o2bnme's Avatar
Senior Member
I had the dealer replace the whole shift **** for this reason.
Old Aug 17, 2001 | 09:25 AM
YosemyTT's Avatar
they are all real on my car - I watched the tech take them all out one by one
Old Aug 17, 2001 | 01:54 PM
225TTR's Avatar
Senior Member
Interesting! Wonder if that's another change like the exhaust hanger and the badge on the wheel.
 Pouria Savadkouei
 Michael S. Palmer
Old Aug 17, 2001 | 02:03 PM
MaesTTro's Avatar
New Member
Default I stopped by the dealer today and they fixed it...
on the spot. Apparently there's a clip in there that holds the collar snug to the bottom of the shifter ****, and mine must have popped off. It's tight and solid now.
Score one for Princeton Audi/VW.
O/T: While waiting for it to be fixed, I looked around the VW showroom and took a look at a "Sport" version of the Beetle they had on the floor (my daughter is almost ready). Pretty cool, nice leather sport seats, upgraded audio, 1.8T engine (150 hp), retractable spoiler, 17" wheels. Sticker was $20,900, and he said they were dealing like crazy. Probably could get it out the door for close to $20K.
He also said there's a Beetle S coming out next year at 250 hp. Scary.
Old Aug 17, 2001 | 02:38 PM
YosemyTT's Avatar
Default I thought we were similar build dates?
Normally when them make these kinds of changes it is split by build date (I'm 07/00 btw).
I've yet to crawl under the car and see how many hangers I have for my pipes!!
For my ref though: how many do you have?
