Brake question for you track junkies...
I'm going to flush out the system with Ate SuperBlue (lots of good experience with it), but need some better pads...don't care how dirty they are, just don't want the really corrosive Hawk Blue dust, if possible...
Thanks!
-Pete
Brakes cannot stand up to repeated slowing from speed. They overheat, fade and you end up losing your brakes. I went straight at the end of the Lime Rock straightaway at about 110 and went off at turn one at Watkins Glen into the gravel trap at over 115! The car was not hurt in either incident, but that is the reason I got my AP Racing setup before hitting the track at Summit Point.
If you are just going to be driving at 5/10th then the stock setup should work just fine, but one you get out there you will want to begin to push the car and yourself. Unfortunately the brakes are not up to what the car is capable of.
How many laps before the Ninety got you at the Glen? It got Dale Jarrett twice last weekend!
Of course a Cup car is going a LOT faster, but it weighs only a bit more than a TTR!
One thing you might try is the new Zimmerman rotors with a true track pad on the front like EBC Yellow stuff. I was planning on this setup but took the Stop Tech plunge!
Good luck!
If you go back to some of the magazine reviews that did a comparison with other cars and the TT, they were leaving the TT on the side of the track for its brakes to cool down after fading during 60-0 stops.
Pads are not the problem. I tried different pads and went off with those as well. I think it is a combination of not enough caliper and the rotors can't disipate the heat fast enough.
0-60 to 0 back to back for more than a few times is also pushing the design criteria. You could easily do more than one 0-60-0 per minute...maybe 2 per minute.
FWIW, I'm surprised you got 3 laps at the Glen before you lost braking. I don't think a stock C5 (admittedly faster) could do 3 hot laps at one time.
Few street-based race cars can maximum brake every lap. IMO, very few race drivers use maximum braking in a road race except in qualifying or trying to pass under braking. Cup cars certainly don't. Who knows even if F1 does.
Thanks for the info.
