Right seat is rattling. Will AoA replace it? Please advise
Old Aug 17, 2001 | 04:47 AM
nighttrain's Avatar
New Member
Default Right seat is rattling. Will AoA replace it? Please advise
It is annoying?. I don't know whether the warranty would cover this. Please advise
Old Aug 17, 2001 | 04:49 AM
orangeTT's Avatar
Junior Member
Default Have had same problem since I bought the car (going on a year)
And they have not replaced it. The dealership simply tells me there's "no fix for it at this time".
<shrug>
Old Aug 17, 2001 | 05:01 AM
BillK's Avatar
Default Not the seat, but they wil replace parts to fix the rattle...
They will actually replace whatever is causing the rattle.
In my case, they replaced the seat frame for the passenger seat.
Voila! No more rattle...
(Don't forget. with the Audi Advantage, your warranty covers <b>everything</b>, from being out of windshield washer fluid to a seat rattle to the transmission falling out of the car...)
Old Aug 17, 2001 | 05:02 AM
rollerskate's Avatar
Member
Default the problem with empty passenger seats ...
the problem with empty passenger seats is that there's no tension kept on the springs, so they can vibrate and rattle.
you want some amount of flex if someone is sitting in the seat, but when the seat is empty, you don't. how to solve both problems?
I don't know. in other cars, you'll see the same issue to one degree or another.
solution #1: carry a passenger. usually not a bad idea, but not always practical.
solution #2: ignore it. it's not that much of a problem, unless there's actually something wrong with the seat that makes it rattle excessively.
solution #3: drive only on smooth roads. vibration and rattling will be worse on bumpy streets. may not be much you can do about that, though!
solution #4: buy some other car. the seats will probably vibrate in that one, too :-(
good luck...
Old Aug 17, 2001 | 05:03 AM
BillK's Avatar
Default Try another dealer.
Read my other post. There is something to fix most everything (except the #$@! privacy shield), so if your dealer is taking a pass, find another dealer.
Old Aug 17, 2001 | 06:13 AM
Ulmer's Avatar
Make sure it's not so far back it's sild off the rail..this happened to me and it rattled like crazy
Old Aug 17, 2001 | 06:50 AM
EighTT's Avatar
Eighth Member of AudiWorld. God-like, glorious and all-knowing.
25 Year Member
Default Here's the drill...
Here's how it works:
1. They'll say that they were unable to recreate the rattle, and give the car back to you with the problem unresolved.
2. You'll bring it back at a later date, and they'll once again say that they were unable to recreate the rattle, and give the car back to you with the problem unresolved.
3. You'll bring it in a 3rd time, and they'll say that they had the technician look at it, and lubricate something or other. They'll give the car back to you with the problem still unresolved.
4. Now very frustrated, you'll complain that the rattle is not being addressed. They'll say that the technician tightened up some kind of assembly. Then, they'll give the car back to you with the problem still unresolved.
5. Furious, you take the car in again at a much later date, and demand a new seat. They'll say that they were unable to recreate the rattle, and give the car back to you with the problem unresolved.
6. Finally, you'll throw up your arms in frustration, having been successfully worn down, and learn to live with the rattle.
Old Aug 17, 2001 | 07:01 AM
orangeTT's Avatar
Junior Member
Default That's frightening ... I kid you not - that is precisely what happened to me
It's like the 6 phases of grieving (there are 6, right?).
 Pouria Savadkouei
 Michael S. Palmer
Hibiscus Red S4
Dec 4, 2004 09:11 AM
WojtekA4
Aug 5, 2003 01:21 PM
dbeck
Jul 21, 2003 07:59 AM
Bruck
Nov 21, 2002 10:50 PM
BMW HUNTER
Dec 5, 2000 06:26 PM
