My dealer told me that you cannot install an OEM Nav system if it wasn't installed when the....
Old Sep 6, 2001 | 01:22 PM
FriscoTT's Avatar
Junior Member
Default My dealer told me that you cannot install an OEM Nav system if it wasn't installed when the....
car was first built at the factory. In other words, the nav system can only be installed at the time of car assembly. Is this correct? If so, damn!!!!!!!
Thanks
Old Sep 6, 2001 | 01:26 PM
Duffer's Avatar
Member
Yes, as far as I know that is true. Don't be too disappointed. You can find alternatives.
Old Sep 6, 2001 | 01:44 PM
evan's Avatar
Senior Member
I believe this is true... though as duffer said, there are very good aftermarket systems.
Old Sep 6, 2001 | 01:53 PM
Gnowknayme's Avatar
If you didn't buy it with the car, there's better aftermarket systems that cost less.
Old Sep 6, 2001 | 02:17 PM
RS-Ralph's Avatar
New Member
Default it's not true!!!
instrument cluster needs to be re-coded, wiring needs to be installed incl. trunk antenna (GPS), hardware etc. the switch will be installed in the center console (pretty easy modification) and the system needs to be adapted for the TT (it's about 1/2 h work if you know what you do (adaption only!).
by the time you add all the costs up, you better off with aftermarket navi!
Maui19
Nov 16, 2004 10:43 AM
truecalling
Aug 29, 2004 02:56 PM
FelonyRuckus
Nov 18, 2002 07:19 AM
BlueS4orce
Jan 5, 2001 06:34 AM
TurboX2
Jan 30, 2000 08:06 PM
