Uh-oh, 2002 VW GTI w/TT 180 output...hmmm
My guess is the next change will be to up the HP on the TT line. Should make for some factory goodies if they stay with the K-03 turbo on the 1.8T 180 motor.
-Brian S.
rated at 150hp and I feel that's pretty accurate.
I wasn't aware of the different codes, Sean. Can I upgrade with factory parts?
The early 1.8T Golfs used a K03 turbo and the newer ones use a K03/K04 hybrid that is the same one as the 180 TT uses.....
It sounds like it would be cost prohibitive to me.....cheaper to upgrade the chip =)
Basically its the same as the 2001... only with more boost and some fuel curve/timing adjustments from what I hear... I'm thinking though, that with the different engine code... there might be some internal differences as well.
You can see the pollution impact on the audi window stickers - the 1.8t cars now pollute less than the previous non-variable timing heads... that plus tweaks to the software give the 150-170/180 hp jump.
Any self respecting TT should have 300 hp
Now that would be nice...
