larry and other car audio mavens...what do you think of dynamat?
Old Sep 8, 2001 | 09:23 AM
economisTT's Avatar
Default larry and other car audio mavens...what do you think of dynamat?
does it really deaden outside road noise and reduce vibrations? is it worth it? and even if it does what it's supposed to do, does it add too much weight to the tt?
thanks!
Old Sep 8, 2001 | 09:35 AM
raVen's Avatar
Member
Default Personal decision. Here's some info that I found helpful. More where that came from, if you want.
<ul><li><a href="http://www.hamiltonjet.com/noise/noiseinfo.html">http://www.hamiltonjet.com/noise/noiseinfo.html</a</li></ul>
Old Sep 8, 2001 | 09:36 AM
Alf Garnett's Avatar
Senior Member
Default Yes good product,
However the trade off for reduced road noise and vibration is cost and weight....As you have probably notice the TT is'nt too shabby in regards to cabin noise, even for the roadster.
The stuff also has an odour for the first few days of install, and if paying someone to install it can get rather costly.
Heres a cheaper alternative to Dynamat<ul><li><a href="http://www.b-quiet.com/index.html">http://www.b-quiet.com/index.html</a</li></ul>
Old Sep 8, 2001 | 11:09 AM
Lone Starr (Ivan)'s Avatar
Elder Member
Jimmie Walker thinks it's "Dyn-O-Mite!"
Old Sep 8, 2001 | 12:48 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Go here for same stuff...1/4 the price!
I have bought this stuff and used it extensively in my Miata (cheap tinny car!). This generic stuff is identical to the Dynamat branded product for a whole lot less........<ul><li><a href="http://www.partsexpress.com/webpage.cfm?&DID=7&WebPage_ID=3">Parts express</a></li></ul>
Old Sep 8, 2001 | 01:33 PM
Larrytt's Avatar
Elder Member
Default Stuff works amazingly well . . . though it is not needed in the TT . ..
It adds LOTS of dead weight. Unless you are going for that final oomph of sound quality or trying to get a bass note just a little deeper, it is not required in a TT. They are already built very solid.
topgun77
TT (Mk3) Discussion
Aug 13, 2016 01:44 PM
Marshall_121
Jul 23, 2004 09:21 AM
spiritwalker
12
Aug 11, 2003 12:10 PM
ardency
Nov 3, 2002 03:57 PM
Jason
Mar 27, 1999 05:55 AM
