Gonna take the plunge and change my own tires this winter
Old Sep 20, 2001 | 05:40 AM
BrampTTon's Avatar
Junior Member
Default Gonna take the plunge and change my own tires this winter
So I ask if the following is correct:
- I need a 17mm extended impact deep well 1/2" socket;
- Torque wrench to do 90 ft/lbs - 120 newton/metres
- Will purchase a lift (there's a reasonably priced 3 ton unit locally);
Can I safely guess my A4 has same lug size?
Where are the lift points on the TT? I believe from an earlier post someone stated not to use the points listed in the manual for a lift.
All help appreciated, I'm not much of an auto mechanic!
Old Sep 20, 2001 | 05:54 AM
RTinNYC(again)'s Avatar
Elder Member
Default Ian, don't do it!!! (there are people who specialize in such things, and we really MUST keep
them gainfully employed, or they'll all start working in non-profit finance, and take away my job)
Just kidding, of course, good luck and Vayez con Dios, etc... ;-)
Old Sep 20, 2001 | 06:10 AM
Larrytt's Avatar
Elder Member
Default Ian, correct on all guesses . . .
as for lift points:
At the front of the car behind each wheel is a rubber donut for the jack point, same at the rear of the car in front of the wheels.
Make certain to cut out a disk of wood to fit inside the metal dish of the jack so that the car is actually resting on the wood and not inside the jacks metal dish. This will prevent the jacks dish from pressing into the belly pan of the car itself.
Old Sep 20, 2001 | 06:21 AM
BrampTTon's Avatar
Junior Member
Thanks much Larry, and I get to use a power tool too! <g>
Old Sep 20, 2001 | 07:50 AM
AkRascal's Avatar
Default Measure the distance from floor to lift point... I came home with my marvelous
new 3.5 T lift from Sears only to discover that while it fit under the TT, it would not slide under Mrs Rascal's S4 in front... had to revert to my smaller, wimpy 2 T lift.
Old Sep 20, 2001 | 08:18 AM
Larrytt's Avatar
Elder Member
Default very simple/easy "fix" for that . . .
get a 2x6 about 18" long in front of each front wheel, add a 2x2 "stopper" at the front and drive onto the 2x6, this will raise the car more than enough off the ground.
63MM
S6 / RS6 (C7 Platform) Discussion
Dec 14, 2015 03:07 PM
CC Rider
Mid Atlantic Discussion
Apr 11, 2005 06:05 AM
BriCK
Apr 5, 2002 05:16 AM
BrampTTon
Oct 2, 2001 04:41 AM
vermontTT
Nov 7, 2000 10:40 AM
