Got some emails regarding my rooftop antenna flag-- more pics...
Old Sep 20, 2001 | 08:10 AM
evan's Avatar
Senior Member
Default Got some emails regarding my rooftop antenna flag-- more pics...
<IMG SRC="http://www.evan.com/tt_pics/roof_flag_02.jpg">
Its a heavy laminate from Kinkos over a home-printed flag. I cut small slits to feed nylon zip ties through... zip tie goes around antenna. Whole assembly slides off the top with some effort if need be. I also used a dot of epoxy on the zip ties to make sure they would stay together and that the laminate wouldn't tear where I cut the slits. Not tested on the freeway yet... some suggested it will be noisy. I'll let you know!
<IMG SRC="http://www.evan.com/tt_pics/roof_flag_03.jpg">
<IMG SRC="http://www.evan.com/tt_pics/roof_flag_04.jpg">
Old Sep 20, 2001 | 08:16 AM
Jason Chen's Avatar
Default I wish we had a better solution than zip ties.....
You should have used clear zip ties instead.
Old Sep 20, 2001 | 08:19 AM
evan's Avatar
Senior Member
I'm sure there is another way to attach it... but I didn't have all day for this project. :-)
Old Sep 20, 2001 | 08:21 AM
rollerskate's Avatar
Member
what holds it in place - does it just jam on?
Old Sep 20, 2001 | 08:23 AM
Larrytt's Avatar
Elder Member
not a bad solution
Old Sep 20, 2001 | 08:27 AM
evan's Avatar
Senior Member
At the moment, yes. Considering some way to make sure it stays put. Ideas?
Old Sep 20, 2001 | 08:29 AM
PGTT's Avatar
I like it! Now I need to make myself one... off to Kinkos!
Old Sep 20, 2001 | 08:30 AM
evan's Avatar
Senior Member
They have a laminate for ID and luggage tags that is just perfect size.
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 20, 2001 | 08:34 AM
Member
Default maybe you want something to "cap" the top of the antenna, but without marring the finish...
so can't use jam screws, etc.
maybe a better idea: if you could find something with threads to match the antenna bolt holt, you could just unscrew the short antenna mast and replace it with your own "custom flagpole". It's probably some kind of metric thread. Anyone know?
Old Sep 20, 2001 | 08:55 AM
HipsTTR's Avatar
Default Check West Marine for Burgee clips
<ul><li><a href="http://www.westmarine.com/webapp/commerce/command/ProductDisplay?prmenbr=201&prrfnbr=6534&store_num= 7&store_name=Gifts%2FHoliday&subdept_num=391&subde pt_name=Flags%20And%20Staffs&class_num=1044&class_ name=Flag%20Accessories">West Mar
