creaking TT fixed
Old Sep 20, 2001 | 02:42 PM
scoTTwouw's Avatar
New Member
Default creaking TT fixed
Took my TT to the dealer because it had been creaking. They lubed up the suspension and sway bar and now it is as quiet as a mouse. SO if any of you have a creaking TT get the suspension and sway bar lubed.
Old Sep 20, 2001 | 02:49 PM
tsltm's Avatar
Elder Member
Thank scott, my dealer had the same fix.
Old Sep 20, 2001 | 03:00 PM
TTurbo's Avatar
Do they have grease fittings or did they lube it up some other way?
Old Sep 20, 2001 | 03:27 PM
jdh's Avatar
jdh
New Member
Thank you!
Old Sep 20, 2001 | 03:37 PM
dpd's Avatar
dpd
Junior Member
Default Re: creaking TT fixed
it's probably going to comeback.if it does,most likely it cracked the ride side swaybar bushing sleeve.if so,it will need a new swaybar.so far the count stands 8 out of 11.
Old Sep 20, 2001 | 03:38 PM
scoTTwouw's Avatar
New Member
Default Re: Do they have grease fittings or did they lube it up some other way?
Not sure how they did but it took them a day and half. They lubed up the suspension first, but when they road tested it it still creaking when turning. They then lubed up the sway bar and then road tested it again. This time no more creaks. If yours is creaking then have the dealer try lubing. BTW - my dealer is Scottdale Audi in Az.
TTsteve
Suspension Tuning Discussion
Jul 17, 2007 04:23 PM
Astrofish
11
Nov 22, 2005 01:23 PM
Speeder Sam
Nov 5, 2001 07:42 PM
grh99
Aug 26, 2001 08:28 AM
