Paging TT Online Mechanics: Need noise dianognistic help
Old Sep 20, 2001 | 07:55 PM
Absolut Todd's Avatar
Junior Member
Default Paging TT Online Mechanics: Need noise dianognistic help
Since swapping out my break pads and bilstein/eibachs i have noticed a clunking sound from the left front area. It sounds like a lose cable is swaying back and forth and hitting something. First i thought it was the brake pad sensor but i have tied it down and still the sound persists. One wild *** idea is that it sounds like the bilsteins or eibachs are compressing. I can't seem to find a cable and am stumped, so I figured I would ask for ideas on things to check.
TIA
Old Sep 20, 2001 | 08:10 PM
INTT's Avatar
Default Not being funny but ------------
Are you sure everything is tight. Wheel, brake caliper, shock bolts. Other than that I couldn't guess.
Old Sep 20, 2001 | 08:17 PM
Junior Member
Yep checked those and all seemed tight. Will probably check again. Believe me, I am befuddled.
Old Sep 20, 2001 | 08:42 PM
INTT's Avatar
Default Does it ---------------
Increase with speed?
Can you feel it through the gear shift or steering wheel? or both.
Is it still there when you apply brakes lightly.
Old Sep 20, 2001 | 08:57 PM
Junior Member
Default It seems most obvious when driving and going over bumps or rough roads, but...
on smoother roads more when turning the wheel. It does not seem noticeable through the steering wheel or through the shifter or when shifting. At times you would swear it sounds like a really quiet, muffled backfire, but its not coming from the back of the car, its coming from front drivers side.
Old Sep 20, 2001 | 09:09 PM
INTT's Avatar
Default Well ----
Running out of ideas Todd, without actually being there to hear. Sort of eliminated any drivetrain problems. One last guess. Are your diverter valve hoses connected? Other than that I can't think of anyhting else.
Old Sep 20, 2001 | 09:29 PM
Junior Member
Thanks for trying. I guess I will have to start at one end and go to the other.
GeorgeInVegas
Oct 1, 2008 07:53 AM
Craigito
Aug 26, 2005 01:05 PM
Stratocaster1422
Jun 30, 2003 06:33 AM
armoara
May 2, 2003 01:47 PM
Catamount90
Oct 12, 2001 12:50 PM
