I checked my compression its 210psi?? whats the spec for the 225? Also was wondering
Old Sep 21, 2001 | 06:58 PM
Boosted's Avatar
Member
Default I checked my compression its 210psi?? whats the spec for the 225? Also was wondering
If anybody knows how to get the colant temp displayed on climate controls.....after the great meltdown its still runnin alittle hot after the rebuild...its about 2mms past 12 oclock on the dial thanks.
Old Sep 21, 2001 | 07:11 PM
PorTTland's Avatar
Member
Default coolant temp trick
I bookmarked this post from a while ago. I've never tried it. Good Luck!<ul><li><a href="https://forums.audiworld.com/tt/msgs/292097.phtml">the trick</a></li></ul>
Old Sep 21, 2001 | 07:36 PM
Boosted's Avatar
Member
thnks..... tryin to figure out if meltdown number two is coming up
Old Sep 21, 2001 | 07:43 PM
dpd's Avatar
dpd
Junior Member
Default Re: I checked my compression its 210psi?? whats the spec for the 225? Also was wondering
is the coolant neon pink [bright]?if it is try diluting it with water,it should be 60% water,40% coolant,any stronger it will run hot
Old Sep 22, 2001 | 06:01 AM
Voice of Reason's Avatar
New Member
Default The compression spec on a gasoline engine is usually around 150 psi.
My temp needle goes over to the first line to the right of 12 o'clock when I'm in stop-and-go traffic. I've considered it to be normal, but I can see why you'd be concerned.
Old Sep 22, 2001 | 06:22 AM
Allentt's Avatar
New Member
Default May I ask what caused the first meltdown...
I'm wondering due to finding oil in my coolant tank.
BlueBiTurbo
11
Sep 8, 2008 11:52 PM
alpinab7
Audi Original "S" Cars
Aug 23, 2007 12:11 PM
dave240Z
18
Sep 1, 2006 08:59 AM
Dmitry D.
9
Jul 5, 2006 11:28 AM
