Does anyone have the Portable Phone Mounting Unit for the TTR as seen at Clair's?
Old Oct 4, 2001 | 11:49 PM
sparkmedia's Avatar
New Member
Default Does anyone have the Portable Phone Mounting Unit for the TTR as seen at Clair's?
Is it worth the $115? Is there an alternative out there? How does the factory phone mount to the TTR? I can see two metal posts hidden by plastic plugs that are most likely used to bolt the handset to... where can I get a bracket that uses these bolts?
While I'm asking questions... Where is the head unit for the mobile phone located in the Roadster? Does the car have a prewired microphone and where (I'm guessing it's at the top of the guage cluster)?
I have the Bose premium sound system.<ul><li><a href="http://www.clairparts.com/shop/accessories.cfm?do=buy&&pid=1508">http://www.clairparts.com/shop/accessories.cfm?do=buy&&pid=1508</a</li></ul>
Old Oct 5, 2001 | 01:28 AM
TT-516's Avatar
New Member
Default It works excellent on my coupe, ...
<center><img src="http://pictureposter.audiworld.com/10467/TT516-handfree.jpg"></center><p>is it worth $115, it depends, the workmanship is very good but please note it's only a ONE piece of plastic mount that fixed on the triangle, and I still have to drill holes in order to fix that OEM handfree base on it. Otherwise, it's so handy in driving since it works automatically with the premium sound system with pre-wired mic behind the steeling wheel. Besides, I've it on the passenger side now. :-)
Old Oct 5, 2001 | 02:59 AM
MichaelTT's Avatar
Senior Member
Default Trying to get use to seeing TT with right side steering...question...
the metal loop/bar attached to the center console...OEM? and what is it for?
Old Oct 5, 2001 | 05:56 AM
nikhil's Avatar
How is your phone wired into the sound system???
Old Oct 5, 2001 | 06:10 AM
TTunable's Avatar
Member
Default I know you can get them from Audi...I had one with my Phone mounted on it.. I bought it from a forum
member.... Shaka?
Old Oct 5, 2001 | 06:11 AM
TT-516's Avatar
New Member
Default That's for the OEM handfree mount, but will block my shifting movement, ...
I removed the mount & only left the metal bar there.
Old Oct 5, 2001 | 06:15 AM
TT-516's Avatar
New Member
You see that cable connected to the phone mount, that is directed to the OEM plug behind the armrest
Old Oct 5, 2001 | 07:24 AM
Larrytt's Avatar
Elder Member
Default If you want to buy one I am thinking of selling mine . . .
Let me know. It is ebony black.
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 5, 2001 | 08:16 PM
sparkmedia's Avatar
New Member
Default Thanks for the help... does anyone have a picture of how the OEM phone mounts to the metal bar?
Also, where is the Control Unit located in the car for the OEM phone?
Rick Pardo
Sep 16, 2003 12:21 PM
Count Floyd
Jun 8, 2001 06:50 AM
TTraXX
Jan 22, 2001 09:49 AM
