So can an aftermarket chip have certain perameters reprogramed..
Old Oct 5, 2001 | 10:29 AM
Bluto's Avatar
Default So can an aftermarket chip have certain perameters reprogramed..
or adjusted? Like A/F ratio, I am still getting some carbon buildup on my tips which leads me to believe, I am running a little rich. Can this be adjusted via the chip?
Larry, you know alot about Garrett, any thoughts here?
Thanks.
Old Oct 5, 2001 | 10:58 AM
Larrytt's Avatar
Elder Member
Default That is what the chip does . . .
if you are running rich, contact PES and let them know that. It is possible Garrett has a newer chip for the 225.
There was a problem with the 180 chips at the beginning and they were redone to fix the richness of the programming. Give them a call, but I would not expect a response from PES on this. Mike can't get them on the phone or even a call back He has talked to Todd/Mike at AWE on a few occasions.
Old Oct 5, 2001 | 11:19 AM
RobbyTT's Avatar
Senior Member
Default Do you drive WOT often?
From my limited understanding, all chip manufacturers program their chips to run a little rich from 80% throttle and on for safety reasons.
Old Oct 5, 2001 | 11:26 AM
Bluto's Avatar
Default good point...
I do tend to go WOT sometimes(well alot) :-)
Spoke to them and I am checking the version of the software.
Old Oct 5, 2001 | 11:27 AM
Bluto's Avatar
Thanks, done and done, checking software version.
DerTT
Feb 8, 2007 01:45 PM
StevenH
Performance and Tuning
Jun 6, 2003 09:05 AM
Audrenalin
Feb 5, 2003 03:04 PM
