Where can I get my turbo timer installed?
Old Oct 6, 2001 | 08:41 AM
AARoadster's Avatar
New Member
Default Where can I get my turbo timer installed?
Anyone know where I can get my Turbo timer installed in my 225 TT Quatto Roadster. I'm not comfortable doing it myself.....
I'm in Allentown, PA... phili area is good too..
Old Oct 6, 2001 | 08:52 AM
Larrytt's Avatar
Elder Member
contact AWE-Tuning, they are in Philadelphia . . . www.awe-tuning.com
Old Oct 6, 2001 | 09:26 AM
efudd105's Avatar
Junior Member
Default Re: Where can I get my turbo timer installed?
What's a turo timer? Is that the gizmo that recirculates oil after the engine is turned off?
If so, how much are they?I'm getting annoyed at having to sit in the car for 1-2 min. before shutting off the engine.
Thanks.
Old Oct 6, 2001 | 01:02 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default You've already got one......
Coolant circulates through the turbo for some time after shutdown(listen and you'll hear it)...it's a standard feature on the 225. Unless you want a timer that keeps the engine running (seems like a PITA to me), you should save your money.....
Old Oct 6, 2001 | 01:05 PM
undrway's Avatar
Default You realize that a turbo timer is not necessary on a 225, right?
They have an OEM pump that circulates oil thru turbo after engine shutoff.
Old Oct 6, 2001 | 01:07 PM
undrway's Avatar
Damitt Steve -- you've scooped me!
Old Oct 6, 2001 | 02:06 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
But only by 3 minutes!
Cruzad3r
Jan 31, 2006 09:39 AM
AnotherS4inTo
Feb 28, 2001 10:08 AM
bush53
Oct 14, 2000 04:38 AM
ultrafreak
Mar 31, 2000 05:36 AM
Max
May 23, 1999 01:30 PM
