Brake Pedal Too High!
Old Oct 6, 2001 | 12:02 PM
mitty's Avatar
New Member
Default Brake Pedal Too High!
We just bought a 2000 FWD TT coupe for my wife. She liked the styling and the handling; I actually did not even test drive one as I am not too keen on front-drivers. My first drive was this morning in the car she bought. Very nice car; I was not even too conscious of the drive wheels being at the wrong end!
But ... the brake pedal is too high. Both of us find ourselves giving the car too much braking just because of the pedal height. We could get used to this, but the pedal is too high to allow me to reach the gas pedal with the side of my foot for double-clutch downshifts. This is very awkward and makes it hard to drive smoothly.
(1) Is this normal? Can others catch the gas pedal for a blip while on the brakes?
(2) Is the pedal height adjustable? No hope under the hood. I crawled under the dash couldn't see enough without pulling trim panels - I could not feel anything that looked like an adjusing clevis.
This is a pretty serious defect in what otherwise seems to be a well-thought-out car.
TIA,
Geo. Anderson<ul><li><a href="http://www.durequip.com/winning/home.htm">I spent too many years racing to drive without double-clutching.</a></li></ul>
Old Oct 6, 2001 | 12:46 PM
corum999's Avatar
New Member
Default Re: Brake Pedal Too High!
I had this same thought, it seems too high.
Old Oct 6, 2001 | 03:29 PM
nikhil's Avatar
I can blip the accel. while pressing down the brake no problem..
Old Oct 6, 2001 | 03:56 PM
OzChris's Avatar
Junior Member
Default Here's a thread that may be relevant to you.
<ul><li><a href="https://forums.audiworld.com/tt/msgs/280818.phtml">https://forums.audiworld.com/tt/msgs/280818.phtml</a</li></ul>
Old Oct 6, 2001 | 11:33 PM
bruceTTeR's Avatar
New Member
Default I've been thinking about attaching a Sparco gas padel to the accelerator but leave the clutch
and brake padels alone, so that I'd build up the gas padel a little bit and the Sparco padel is wider on the bottom. What does you guys think?
Old Oct 7, 2001 | 05:45 AM
MIB's Avatar
MIB
New Member
Default Your first post here isn't it?
Your wife bought a used TT which you didn't test drive and now you find you dislike the pedal positions? Hmmm.
You might try adjusting the seat to find the best position for each driver. It may take a while, but I think you'll find the sweet spot for the seat.
Anything you like about the car?
Old Oct 7, 2001 | 05:54 AM
mitty's Avatar
New Member
Default Yes, and 4 out of 5 responses are on-topic.
There's always at least one supercilious jerk on any board.
Old Oct 7, 2001 | 02:41 PM
Lone Starr (Ivan)'s Avatar
Elder Member
Default I beleive the sensitivity on MItty's part has to do with your repetetive and unnecesary mention of
how you dislike FWD cars. Not the most tactful way to get help, particularly among enthusiasts of car that is Fwd.
Otherwise, there are people, as you can see, that feel the same way you do. I have no problem double clutching with my size 11's.
I have found in my experience that every car takes practice to drive well. Haven't you?
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 7, 2001 | 03:27 PM
mitty's Avatar
New Member
Default Re: I beleive the sensitivity on MItty's part has to do with your repetetive and unnecesary mention
&gt;&gt;dislike FWD cars ... the most tactful way&lt;&lt;
Agreed. Not the place for a debate. If you're interested in the physics of it, e-mail me off line. george@willowlane.net
&gt;&gt;I have no problem double clutching with my size 11's. &lt;&lt;
Sounds like quite a few people have a brake pedal height that works o.k. for heel/toe. I'm still hoping someone can tell me whether the brake pedal height is adjustable. I will probably just have to dig under there until I find out for myself.
&gt;&gt; I have found in my experience that every car takes practice to drive well. Haven't
you?&lt;&lt;
Absolutely, but setting up the driving position comes first. In the case of this particular TT, there is no way to reach the gas pedal under normal braking pressures. Hence, the post.
Old Oct 7, 2001 | 04:35 PM
Elder Member
Default I will admit that it was not easy to learn to heel-toe in my TT.
Enjoy the smile it surely will put on your wife's face.
builthatch
Q5/SQ5 MKI (8R) Discussion
Mar 15, 2015 07:12 PM
adrien
13
Aug 12, 2003 05:16 PM
kwsailnj
Apr 6, 2003 02:40 PM
AKSPDRAC
Audi allroad
11
Nov 7, 2002 07:21 AM
AF 4.2
Mar 24, 2001 11:36 AM
