ARGGH! 01 TTRQ doesn't qualify for quattro Club Events
Old Oct 27, 2001 | 04:58 PM
HipsTTR's Avatar
Default ARGGH! 01 TTRQ doesn't qualify for quattro Club Events
There is a new rule this year called the broom handle rule. With the helmet on, there must be 2" clearance between the top of the helmet and a broom handle running from the top of the roll bar to the top of the windshield.
Mine measured at 1.25". (And I dont need any silly comments!!)
Someone mentioned that there may be a bolt on assemebly that will extend the roll bar.
Any ideas?
Old Oct 27, 2001 | 05:04 PM
chris98GTi's Avatar
New Member
Default Re: ARGGH! 01 TTRQ doesn't qualify for quattro Club Events
That really stinks about the new rule. Could you be exempt from this by using the factory hardtop on the track, or is that not solid enough?
BTW, it was nice meeting you on the drive today. Thanks for coming out
Chris Keast
NorCal VW
Old Oct 27, 2001 | 05:17 PM
ooyahhh's Avatar
Junior Member
Default Re: It's worse than that. The upcomming quattro events at
Willow Springs and laguna Seca are put on by Speed trial USA. Their requirement for convertibles is a SCCA approved roll bar. No stock roll bars allowed. See link<ul><li><a href="http://www.speedtrialusa.com/drifting.htm">http://www.speedtrialusa.com/drifting.htm</a</li></ul>
Old Oct 27, 2001 | 07:03 PM
gtt's Avatar
gtt
you could remove stock seat and put a race seat in possibly.
Old Oct 27, 2001 | 07:39 PM
EBITDA's Avatar
New Member
Default I assume you have done this, but check with the actual person
running the event. In Minnesota, the rule changes at each event depending on who the person is running the event. Sometimes it's the broom stick rule, sometimes not. Sometimes it's tops up, sometimes not. I have a coupe, but when the broom stick rule is in effect, roadsters typically don't show up. I have not seen a fix.
Old Oct 28, 2001 | 01:17 AM
juliem's Avatar
Default I was wondering that.. makes the car even heavier though
Ended up using my Avant last track that wouldn't take the TT Avant was surprising good and I think it weighs less!
Old Oct 28, 2001 | 02:48 AM
Rennen's Avatar
Elder Member
Default That's why I couldn't attend the Summmit Point event. Did you try putting the seat..
....as low as it will go and really slouching when the measurement is taken? Seriously....
Old Oct 28, 2001 | 03:39 AM
225TTR's Avatar
Senior Member
Default Well, it's not exactly the CAR that doesn't qualify .....
<center><img src="http://pictureposter.audiworld.com/4155/broomstickrule.1.jpg"></center><p>Try putting the seat all the way down.
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 28, 2001 | 06:40 AM
joe@vwvortex's Avatar
Yup the Avant is about 100lbs lighter. The roadster is so heavy already whats a few more pounds
Old Oct 28, 2001 | 07:04 AM
HipsTTR's Avatar
Obviously, I did that!
