tech question on vehicle dynamics
That heavily overworks the fronts before the rears resulting in "push" or understeer as we approach the limit of adhesion. By adding quattro we take some of the drive work off the fronts and make the rears work harder (and add a little weight to the rear also). This helps balance the work we are asking the tires to do.
Another problem with front-heavy cars with the engine at or ahead of the front wheel centerline (Audi) is polar moment of inertia, or simply the cars reluctance to start a turn, and its reluctance to stop the turn. The standard analogy is the barbell on a long shaft supported on your shoulders: it's more difficult to start spinning your body and to stop than if you had the same amount of weight strapped to your belt (or were built like me).
If one had to make one end heavier, a rear-drive vehicle with rear weight bias (Porsche 911) lets the fronts do lots of the cornering ewhile letting the rears mainly put power to the ground.
With high power-to-weight ratios (F1, Cart, etc) weight is biased to the rear and rear has larger tires mainly to get the power down.
Balancing by adjusting corner weights on a street car can have only a minor effect. You can't move weight from the front to the back by adjusting spring heights, but only by physically moving parts of the car or ballast. You can transfer weight diagonally, but TOTAL front/rear and TOTAL left/right won't change.
Some folks won't believe this. One exception: if you raised the front 4 inches and dropped the rear 4 inches, you could move about 25 lbs from the front to the rear on a 30000 lb TT. A 1 inch rake (instead of 8) would reduce that to about 3 lbs., and you'd be raked the wrong way for aero.
Yes, all else being equal (which it never is), balanced is better than massively front heavy.
BTW, during hard braking, TT has about 80+% of its weight on fronts while a 40-60 Porsche 911 is almost 50-50 or just slightly front heavy. That explains why 911's have big brakes all around, and why TT doesn't.
My $.02
).... lol now all I need is some good coilovers and a scale.
