Regarding Diverter Valves....
Old Nov 30, 2001 | 01:04 PM
LENELSA's Avatar
New Member
Default Regarding Diverter Valves....
#1.) Will installing an aftermarket DV void my warranty ??
#2.) Which one is best: Bailey Motorsports, Stratmoshere, or ........
#3.) How easy is a self-install (I'm pretty car savvy)
Thanks for enlightenment !!!!!!
Old Nov 30, 2001 | 01:24 PM
FriscoTT's Avatar
Junior Member
Default #1)Technically, yes #2)Personal Preference #3) Very EZ (and I'm not mechanically savvy) more details
#1) An aftermarket DV will void any warranty that has anything to do directly with the DV, if the dealer can prove that the aftermarket DV caused the failure (turbo, engine, etc..) then you are out of luck. Depending on the dealer, but many will blame an aftermarket part for ANY failure.
#2) I think ANY aftermarket DV is better than the OEM. I have the FORGE from Stratmosphere as that was the most recommended here when I was in the market for one.
#3) Install is easy. The most difficult part is removing the factory straps that keep the hoses in place. I recommend using a dremmel tool and just cut them off(thanks to Evan for doing my DV).
Old Nov 30, 2001 | 01:26 PM
BillK's Avatar
Default Re: Regarding Diverter Valves....
1) Officially, <b>yes</b>, they do void your engine warranty. In reality, "maybe," it depends what goes wrong where in your engine and if your dealer and/or AoA decide to go by the book.
2) The Bailey/Forge issue seems pretty evenly split.
3) Installation is pretty easy, probably 30 minutes to an hour (the hardest part is getting the OEM single-use clamps off)
Old Nov 30, 2001 | 01:27 PM
FriscoTT's Avatar
Junior Member
Hey, we have identical answers!!!! Great minds think alike ;-)
Old Nov 30, 2001 | 01:57 PM
LENELSA's Avatar
New Member
Do DV's come w/ instructions??
Old Nov 30, 2001 | 02:17 PM
225TTR's Avatar
Senior Member
Default Go here: (at least until @Home pulls the plug)
<ul><li><a href="http://members.home.net/eerickso">Ellen and Michael's TT Site</a></li></ul>
Old Dec 1, 2001 | 09:34 AM
0TT0 BURNER's Avatar
Junior Member
AoA new policy is to void at their descretion if car has any non-Audi parts. Be cool to your dealer.
Old Dec 1, 2001 | 01:10 PM
yellowjackeTT's Avatar
New Member
Default Please ... a little guidance for a neophyte.
I'm beginning to understand that to increase my 225's performance, I can install a high-tech aftermarket diverter valve (spins up the turbo quicker and keeps it spinning longer) and replace the "chip" (which I infer controls the air/fuel mixture, perhaps controls the turbo boost, and definitely removes the mph limitation). But any of the above voids my warranty. Does that sound about right?
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 1, 2001 | 02:03 PM
225TTR's Avatar
Senior Member
Default About right, except the DV wouldn't normally increase performance unless the OEM valve were failing
The sad part about this is that the OEM DVs are notorious for failing. They are plastic POS and a very low-quality part. A TT deserves better.
Also, none of this will necessarily void your warranty - it all depends on your dealer. Technically, AoA can void your warranty if you switch to non-OEM wiper blades.
Old Dec 1, 2001 | 02:15 PM
New Member
Danke!
AJN334
10
Sep 14, 2004 02:37 PM
huwla
Apr 4, 2003 06:34 AM
audimanS4
Jul 14, 2002 11:18 AM
LENELSA
Feb 19, 2002 05:12 PM
S42001
48
Jun 25, 2001 05:33 PM
