larry -- if you're still here -- do you have any information on some tt's having a slightly larger..
Old Dec 1, 2001 | 08:30 PM
economisTT's Avatar
Default larry -- if you're still here -- do you have any information on some tt's having a slightly larger..
rear hub? i'm trying to get new rear brake rotors, and the aftermarket ones i've gotten that are supposed to fit on the 180qc are slightly too small...a guy i work with on my car who owns a repair facility called audi and they told him that some tt's require a different rear rotor than most -- and that there were none of these rotors in the u.s.!
Old Dec 1, 2001 | 08:46 PM
raVen's Avatar
Member
Dave, unless you have 225 rear brakes some how, I can't see anything being different.
Old Dec 1, 2001 | 08:57 PM
Larrytt's Avatar
Elder Member
Default Yes, 3 different rear discs for the TT . . .
9.1" FronTTrak
9.4" 180TTQ
10.0" or 10.1" 225TTQ I forget which.
Old Dec 1, 2001 | 08:59 PM
economisTT's Avatar
Default the rear brake rotors that are supposed to be for the 180qc...
are simply too small for my tt...i've tried two sets of aftermarket rotors and one set of oem rotors...the hub is about a quarter of an inch larger than the opening in the rotors...when my friend called audi about this, they asked for my vin, and when they had it they said that some tt's needed a different rotor than the others! very strange!
Old Dec 1, 2001 | 09:03 PM
Larrytt's Avatar
Elder Member
Default oh, you meant the rotor thickness? I don't know what they are . . .
just what I have read.
Old Dec 1, 2001 | 09:09 PM
economisTT's Avatar
Default very strange -- i'm sure that i've gotten the 180q rotors rather than the...
fronttrak.
i think i need to go down to my audi dealer and have them take a look at the hub and see if they have a rotor to fit it -- and exactly what the specs of that rotor are.
ralf has sent me two sets of rotors that are supposed to be for the 180q -- and both of them were slightly too small...and then i tried a set of oem rotors that also were supposed to be for the 180q, and it was too small by the same amount.
it's possible that i got fronttrak rotors each time, but that seems unlikely.
Old Dec 1, 2001 | 09:10 PM
economisTT's Avatar
no -- i mean the diameter of the opening on the rotor that fits over the wheel hub
Old Dec 1, 2001 | 09:14 PM
Larrytt's Avatar
Elder Member
seriously? they changed the freaking hub? idiots! freakin' "German Engineers"! lol
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 1, 2001 | 09:15 PM
economisTT's Avatar
are the diameters of the openings different for each one as well?
Old Dec 1, 2001 | 09:16 PM
economisTT's Avatar
Default i believe that this is true on a limited number of tt's that were produced...i'll try to get...
a better answer from my audi parts guy on monday and let you know.
