Error codes: Technician @ dealership having difficulties resetting the service indicator...(more)
Old Dec 3, 2001 | 09:47 AM
FriscoTT's Avatar
Junior Member
Default Error codes: Technician @ dealership having difficulties resetting the service indicator...(more)
I just brought my car to Rector for scheduled maintenance and got a call from the service manager asking me if I chipped the car or made any modifications to the engine. Of course I said "Uh, no." It's a good thing I swapped out my Forge DV and put the OEM DV back in. Anyway, the service manager said that the technician keeps getting kicked out when he tries to reset the Service Indicator...After 3 tries, he was finally able to get in and do the reset. He said that the service indicator "might" tell me that the next service is due sooner than it really is. He faxed me the error codes, please tell me if this has anything to do with the Forge DV. here it is exactly as I got it:
8N1920930C KOMBI+WEGFHRS. M73 D24
Coding 06244
Adaptation
Adaptation
Adaptation
Channel 2 Adaptation 0
Text 577 Text 577 <-1 3->
Adaptation
Adaptation
Adaptation
Channel 44 Adaptation 365
max. val. Insp. in 1 days <-1 3->
Channel 43 Adaptation 5
max. val. Oil in lit000 km <-1 3->
Any ideas?
Old Dec 3, 2001 | 10:09 AM
Larrytt's Avatar
Elder Member
Default The DV has nothing to do with the electronics in the car.
it is a mechanical part, no wires are connected to it. Don't worry about it.
Old Dec 3, 2001 | 10:27 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default There's a simple service indicator reset procedure but......>>
I can't get mine to reset either....Minor issue IMO.....<ul><li><a href="https://forums.audiworld.com/tt/msgs/327063.phtml">Service reset procedure</a></li></ul>
Old Dec 3, 2001 | 12:16 PM
INTT's Avatar
Default Reset mine a few days ago. The only thing...
I had trouble with is doing it fast enough. From what I can tell it only gives you a few seconds to twist the left button. Then I also found that you have to turn the button rather firmly. Took me a few tries, but it works.
Old Dec 3, 2001 | 12:50 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
I ran out of patience.....Will have to try again! Thanks...
Old Dec 3, 2001 | 01:39 PM
john s's Avatar
Member
Default I know what your problem is...
you're dealing with an idiot. Need to enter the value 0 five times in the channel #2 slot only. Channels 43 & 44 are not to be programmed.
Old Dec 3, 2001 | 02:55 PM
FriscoTT's Avatar
Junior Member
So, are most technicians idiots?
Old Dec 3, 2001 | 06:23 PM
john s's Avatar
Member
Default The shoe fits if you can't perform standard preventive maintenance.
Whither it be an oil drain or a service indicator reset. It's downright scary to think that Audi has service personnel working over cars that don't know how to reset a service indicator.
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 3, 2001 | 07:52 PM
Larrytt's Avatar
Elder Member
Default Come on John, maybe the Tech was absent from class that day . . .
it does happen. I missed many a class in school and still to this day have some trouble not only tieing my shoes, but also playing well with others. lol
Bad Andy
Q5/SQ5 MKI (8R) Discussion
19
Dec 10, 2014 10:37 PM
sutherland
Oct 28, 2008 04:10 AM
S6AAN
Audi Original "S" Cars
Jan 25, 2008 07:27 AM
d4m0n
10
Dec 19, 2007 05:42 AM
gofastblue
RS4 (B7 Platform) Discussion
Jun 25, 2007 07:27 AM
