Where's the Frik'n Bose factory amp hidding???
Old Dec 3, 2001 | 12:07 PM
JackF's Avatar
New Member
Default Where's the Frik'n Bose factory amp hidding???
I am going crazy looking for the factory bose amp in my roadster. I have removed every panel behind the seats. I even checked in the trunk, behind the side panels. The only thing I have not removed is the storage compartment "black piece" behind the passenger seat below after removing the panels, because it has the trunk release attached to it and didn't want to mess with it. But I was able to look under it by lifting it and did see anything. I noticed that all the cables that come from the front were taped and ran through the side of the well on the passenger side once the panel was removed, but I can't find the amp. Can you help me??? Also, how big is it ??
Thanks a bunch,
Jack
Old Dec 3, 2001 | 12:24 PM
Gnowknayme's Avatar
I could tell you if you had a coupe!
Old Dec 3, 2001 | 12:28 PM
JustJeff's Avatar
Default Isn't it in this area?
<img src="http://203.198.49.154/vorsicht/public/tt_001/DSC00153.JPG">
Old Dec 3, 2001 | 12:30 PM
Lone Starr (Ivan)'s Avatar
Elder Member
Put some clothes on that think. Nekkid TT! Nekkid TT!
Old Dec 3, 2001 | 12:38 PM
JackF's Avatar
New Member
Default Byt he way, Jeff..
How do you like the headliner from stratmosphere? I'm thinking of getting one. Is it worth the expense. How hard to install is it?
Jack
Old Dec 3, 2001 | 12:39 PM
JackF's Avatar
New Member
Default Re: Isn't it in this area?
Nope, this is where i first looked after taking everything apart...
JustJeff's Avatar
contact Wilson_TT. That is where the pic comes from. He took lots of photos of the area, but you are right, it's not obvious.
Email:wilson@vorsicht@org.hk<ul><li><a href="http://www.wilson-tt.com/">Wilson_TT</a></li></ul>
Old Dec 3, 2001 | 12:51 PM
JustJeff's Avatar
Default Headliner?
I like it now that it's in.
Worth the expense?
Not really, a bit over-priced. It should be closer to $250-300, IMHO.
It *does* drop the ambient noise, and so far, is a mild improvement on retaining heat.
It's a bitch to install, 'cuz it's not real intuative. The instructions help, but you will need to modify the install proceedure, and be fairly limber, as you rut around in the car, top partly up/down.
I was sitting on my knees, facing backward a lot.
The hardest part is the end, where you need to remove the front fasica piece at the front of the top. Well, you can't really remove it, because you can't get the top release handle off.
You need to remove a metal bar under this piece, each side of the top hanlde, to get the headliner under this to tighten it.
If you could remove this trim piece completely, it would make it a lot easier.
Also, it would help to have two people do this step.
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 3, 2001 | 05:58 PM
PorTTland's Avatar
Member
Default This may or may not help. Scroll down to the Roadster graphic.
<ul><li><a href="https://www.audiworld.com/news/00/01roadster/bose.shtml">https://www.audiworld.com/news/00/01roadster/bose.shtml</a</li></ul>
Cl04cbl
Oct 19, 2012 03:49 AM
WoodburyTT
May 19, 2007 07:09 PM
CUL8R
Apr 6, 2006 12:52 PM
TonyStarkz
Mar 4, 2005 11:45 AM
