LLtek air intake...anyone with experience on a 225 Q TT?
Old Dec 3, 2001 | 12:34 PM
jhood's Avatar
New Member
Default LLtek air intake...anyone with experience on a 225 Q TT?
Anyone install one of these? If so, what are your impressions? Thanks!!!
Old Dec 3, 2001 | 12:38 PM
Jason Chen's Avatar
i think you would get the same performance driving your car in 120degree weather using stock box.
Old Dec 3, 2001 | 01:05 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Needs to be modded to avoid the heat issues.....
<center><img src="http://pictureposter.audiworld.com/13940/insulationmod.jpg"></center><p>email me for more details...<ul><li><a href="https://forums.audiworld.com/tt/msgs/363177.phtml">Earlier post RE: lltek mods....</a></li></ul>
Old Dec 3, 2001 | 01:51 PM
FlooriTT's Avatar
Default works pretty good.
the only thing is what ttschwing was talking about with the heat issues. I've also noticed that after a spirited drive the engine will Idle a little hot. as for performance, not too much went to test and tune at bandimere speedway before and after the intake and only noticed a couple hundredths of second gain in the 60', 330' and 1000' times, the Et and speed were the same. however I don't know here you live but here in colorado at night (now, not usually) its maybe 40 degrees at the max so the turbo is spooling much better. The intake also makes the turbo much louder, you'll hear alouder wssssssshshhhhhhhPSHHH like noise when accelerating.
Old Dec 3, 2001 | 03:22 PM
Rennen's Avatar
Elder Member
Default Not worth the money. Makes your car sound like Darth Vader and doesn't improve....
...performance for squat. I have the measurements and graphs to back it up.
TonyStarkz
9
Oct 3, 2004 10:09 AM
jam75944
Apr 21, 2003 02:27 PM
jam75944
Apr 28, 2002 10:57 AM
SoCalATTorney
13
Nov 5, 2001 02:48 PM
FlooriTT
May 4, 2001 07:15 AM
