I'm about to use a hydraulic jack to put M-2s on my car but
Is there anything about which I should be very careful? I know to be careful of the brake cable(line?) in the back, but are there any other
things to avoid?
Many thanks.
So they had to use manual jacks to lift the car. Pain in the butt. Are the sideskirts of the TT really that weak?
Make certain the car is in gear, emergency brake is on and you "break the bolts" before lifting the car off the ground.
Sounds like you went to an idiot to mount your tires. That part of ANY car is not designed to support the weight of the car. That is what jacking points are for.
Have you crawled under and looked for the 4 damage points they caused on the car? Some serious dents I am certain.
Please contact the server administrator, webmaster@automotivetools.com and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log.
