Bilstein Heavy Duty or Sports?
Old Dec 13, 2001 | 01:21 AM
KARL BENZ's Avatar
New Member
Default Bilstein Heavy Duty or Sports?
Which of these best matches the standard shocks (with standard springs) on a 225 coupe. I want to swap out the OEM ones when I get new tires and I don't want firmer shocks. I've searched and read some earlier posts on this subject but it gets a little unclear when non standard springs come into the disscusion. So forgive me if its a dumb question or its been delt with before.
Thanks
Karl
Old Dec 13, 2001 | 02:37 AM
BillK's Avatar
Default I was told the Bilstein HDs would give a "little bit stiffer than stock" ride...
They were generally recommended without entering the kidney-killing category.
The question is, why swap out shocks? You are almost certainly still under warranty if the old ones are shot, and if they're not why risk your suspension warranty?
Just my $.02...
Old Dec 13, 2001 | 02:44 AM
AkRascal's Avatar
Default I have sports.....
Obviously I can't speak to the HD version, but am very happy with these. They are a bit stiffer than stock, but dampen the bumps so much better that the ride is much improved and of course the handling too. Springs are stock. The TT is my daily driver and I, as you, did not want a harsh ride. My co-pilot, Mrs Rascal, agrees that they improve the over-all ride.
Old Dec 13, 2001 | 03:36 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default HD's and stock springs are a very good combo......
I ran mine this way for a few months and liked it a lot. It will be stiffer than stock, but ride quality will remain good. HD's are mean't to be used with the stock springs although will work fine later if you lower. Sports are 22mm shorter and meant for dropped situations. No one's ever definitively proven whether the valving is the same or not but we suspect it is....
Steve
Old Dec 13, 2001 | 06:07 AM
Jay 225TTR's Avatar
New Member
HD's are for stock springs, Sports are for lowering springs.
Old Dec 13, 2001 | 06:35 AM
gtt's Avatar
gtt
ditto..and according to Darrell at shox.com and Bilstein valving is the same.
Old Dec 13, 2001 | 07:08 AM
John P. (TT 225)'s Avatar
yep, confirms what I've been told
Old Dec 13, 2001 | 07:09 AM
Karl--before you buy . . . I should be posting group buy details today (finally)
 Pouria Savadkouei
 Michael S. Palmer
GreenAlienTT
Mar 17, 2005 04:53 AM
dbibeau
15
Jul 2, 2004 10:51 AM
Marc Collins
9
Jul 21, 2002 03:28 PM
juliem
9
May 4, 2001 06:35 PM
Dave Griswold
Feb 12, 2001 10:28 AM
