Is 3M Rubbing compound the best product to remove swirls with?
Old Dec 13, 2001 | 04:48 AM
Bluto's Avatar
Default Is 3M Rubbing compound the best product to remove swirls with?
need something a bit stronger than Z5 yet not too abrasive. And does the 3M RC need to be applied/removed w/an orbital polisher?
Thanks.
Old Dec 13, 2001 | 04:50 AM
hoTTub's Avatar
Member
Default I have used it with good success.....
if you read the bottle, it tells you how to apply it with both the orbital or by hand.
TTexasAlum's Avatar
New Member
Default Scratches too!
The zaino rep here in Dallas uses it also. Buy the "Hand Glaze" it's the one to get.
Old Dec 13, 2001 | 05:17 AM
Bluto's Avatar
great thanks!
Old Dec 13, 2001 | 05:18 AM
Bluto's Avatar
Thanks sean
Old Dec 13, 2001 | 05:33 AM
VenTTed's Avatar
Imperial Hand Glaze... works wonders!
Old Dec 13, 2001 | 05:37 AM
Bluto's Avatar
is that part of the 3M line of products?
Old Dec 13, 2001 | 06:06 AM
Bob W.'s Avatar
25 Year Member
Default worked for me...
...make sure to get the right one: it comes in two formulas, one for dark colors, one for light colors.
And be forewarned, it will permanently stain any clothing it comes into contact with...I ruined a perfectly good Audi t-shirt with that stuff :-(
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 13, 2001 | 06:23 AM
gtt's Avatar
gtt
Default try 3m polishing pad glaze first. Sal said if z5 doesn't work to use only this.
After speaking with him over a year ago contemplating zaino and the swirls I had it's what he recomended as the solution. Rubbing compound too harsh unless you have scratches you can feel. I've had excellent results using the following on scratches left by cat paws on the hood and other marks. I go mild first ie. p21s paint cleanser and if that does not help then 3m polishing pad glaze then re-wax. If I had worse scratches or bad swirls then I would step up to the rubbing compound.
Old Dec 18, 2001 | 06:13 AM
VenTTed's Avatar
yes!
beoperson
Q7 MK 1 Discussion
Dec 13, 2008 11:29 PM
moTAP
Mar 13, 2003 03:52 PM
gacaudi
Oct 24, 2002 03:46 PM
mpwolf
Auto Detailing Discussion
13
Aug 9, 2002 07:36 PM
2000TTC
Jun 14, 2001 12:11 PM
