OT... Building a computer and could use some help..
John
Look for names like Abit, Asus when buying a motherboard... they have been the standard for years. There are a few other nice ones out there.
That keyboard does exist... I have seen a few different versions in the past.
Want some honest help and good prices? Call Computer Simplistics 661-296-4315... they will help you out, get you good pricing and I know the owner.
If you want to save some money on motherboard, you may want to check into the msi board. I have built quite a few of computers using the msi board, and so far they have been trouble free.
Good luck!
Peter
Why go wiith celeron? Durons have similarly priced and have twice the bus speed, 266 vs 133. And with AMD you can use DDR, which utilizes the 266 Bus, unlike Celerons that run only at 133.
If you decided to get an athlon processor, you might want to get a motherboard that uses DDR momory. Like what Gary said, DDR runs twice as fast as the traditional PC133 memory.
-the BUS speed of your CPU
-Bandwith of the memory
-Speed of the memory (CAS 1 vs CAS 3 memories)
-You'll want a 7200rpm HD (not 5400)
-A good graphics card (which is a big determinant of the speed and efficiency of your computer) -> some cards use SDRAM vs DDR, plus amount of memory
-the number of expansion slots for future upgrades
-number of memory slots, one strip of 256 megs is better than two 128
-the maximum RAM the motherboard allows
-number of fans you can attach -> like our TT's the cooler the better
-what kind of case you will be putting these components into -> you'll want an ATX with at least 350 Watts
Plus many other things. Building a computer sounds and looks complicated, but if you have the right parts, it just all falls into place and very self explanitory.
