How many quarts do I need to change transmission oil? I know engine oil is 5 TIAqt.
Old Jan 6, 2002 | 10:09 AM
Edwin's Avatar
Junior Member
Old Jan 6, 2002 | 10:22 AM
OTOF's Avatar
Elder Member
Default See page 5 on the linked document
<ul><li><a href="http://www.springbreakdaytonabeach.com/vwtech/www.vwwebsource.com/vwtechcontent/audipdf/a000102.pdf">http://www.springbreakdaytonabeach.com/vwtech/www.vwwebsource.com/vwtechcontent/audipdf/a000102.pdf</a</li></ul>
Old Jan 6, 2002 | 10:39 AM
ross@downforce.net's Avatar
Member
Default also - since i'm switching to redline next week...what weight
for final drive and tranny on AWD? that doc lists capacities but not specs...
thanks
Old Jan 6, 2002 | 10:48 AM
fredfromny's Avatar
Default Pg -5 footnote2 - Audi part number G 005 000
or your warranty may be voided.
I use redline MT-90 and like the feel in my FWD. Synthetic 75W90 GL-4. If you have a problem you can always switch back.
Old Jan 6, 2002 | 10:56 AM
Member
Default so its the same for the final drive as for the main tranny?
I am replacing the gear oil in both my 99 A4 and my TT with MT-90 but wondered what the extra 1.1 liter of fluid was for...
Old Jan 6, 2002 | 11:12 AM
fredfromny's Avatar
Default I'd check to see if final drive is GL-5.
GL-4 for transmission, GL-5 for final drive.<ul><li><a href="https://forums.audiworld.com/tt/msgs/312034.phtml">old post</a></li></ul>
Old Jan 6, 2002 | 11:16 AM
Member
anyone replace the final drive fluid here? Anyone? Bueller?
Old Jan 6, 2002 | 11:34 AM
Jim TT's Avatar
Use 75 w90 syn, spec G 052 911 A....I use Mobil 1 (O2j fwd)
 Pouria Savadkouei
 Michael S. Palmer
Old Jan 6, 2002 | 11:57 AM
fredfromny's Avatar
Default Another old post...
<ul><li><a href="https://forums.audiworld.com/tt/msgs/406899.phtml">Oil confusion</a></li></ul>
Old Jan 6, 2002 | 12:19 PM
Lloyd of the Rings's Avatar
Redline recommends MTL for gearbox,75W-90 for the rear diff.
