Aren't there problems with using GL-5 oil (Mobil 1) if tranny uses GL-4? (more)
I'm still not sure whether to use Mobil 1 Syth Gear Lubricant or Redline MT90 and 75w90 for tranny/final drive.
Also, I may be misunderstanding something, but will the dealer both replace the tranny/final drive with either of the 2 oils? Thanks!
Edwin
225 ttc
"Got TT?"
Most manufacturers of manual transmissions and transaxles recommend an 80W or 90W GL-4 lubricant. GL-5 gears oils which are required in hypoid differentials are not used in most synchromesh transmissions because the chemicals used to provide the extreme pressure protection can be corrosive to synchronizers, which are commonly made of brass or bronze. Typically, the use of a GL-5 lubricant in a synchromesh transmission will shorten the synchronizer life by one half. The extreme pressure requirements of spur gears and helical gears found in transmissions are not nearly as great as found in rear-wheel drive differentials. A GL-4 lubricant provides adequate protection for most manual transmissions, unless a unique design consideration requires the extra protection of a GL-5.
