Need advise about a flat tire
Old Jan 6, 2002 | 07:32 PM
mia67's Avatar
New Member
Default Need advise about a flat tire
I got a flat tire from a nail when I dropped off the TT for service. The Audi dealer guy tells me they patched it but it may not hold and the tire may need to be replaced. Sure enough, the tire is losing air.
Questions...
Can't it be patched without replacing the tire? Where should I go to get the job done correctly? If I do need a new tire, do I have to purchase 2 tires so it's balanced?
Thanks
Old Jan 6, 2002 | 07:41 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Tires can be successfuly repaired.......
as long as the hole is in the tread area. You may need to dismount the tire and do an inside patch (best way). I had a tire plugged after picking up a 4 inch lag bolt (a fat one) while on a business trip. I've had no problems in 4,000 miles and have run as high as 125. You do not need to replace tires in pairs unless they have high miles on them....
Old Jan 6, 2002 | 07:49 PM
axel's Avatar
Buy a new tire, it just lost it's "H" rating
Old Jan 6, 2002 | 07:51 PM
mia67's Avatar
New Member
Default Re: Tires can be successfuly repaired.......
The hole is in the thread area so it sounds like it can be plugged. Should I just take it to some place like Dobbs since the Audi dealer didn't fix the hole properly?
Thanks
Old Jan 6, 2002 | 07:52 PM
mia67's Avatar
New Member
Huh...what's "H" rating?
Old Jan 6, 2002 | 07:55 PM
axel's Avatar
It's top speed rating
Old Jan 6, 2002 | 07:56 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default You might be able to get a new tire out of this.......>>
Tell em you're not happy about the speed rating being devalued, to say nothing of it not holding air....
IDMS4
S4 (B9 Platform) Discussion
Sep 23, 2017 08:52 AM
imdakine1
Q5/SQ5 MKI (8R) Discussion
13
Feb 26, 2017 01:52 PM
Airbus
32
Dec 14, 2004 07:35 AM
Mark Heuchert
Wheels & Tires Discussion
Mar 11, 1999 02:34 PM
