RioCar People: wiring question
Old Jan 7, 2002 | 07:00 AM
sTTanford's Avatar
Junior Member
Default RioCar People: wiring question
can somebody just confirm for me (beofre I make any purchases), if I get a RioCar I also buy a regular amp? the Bose system already has an amp, but is that only used for the woofer?
also, the Bose system has about 8 speakers right? do they all play the same respective left/right signal? or are the signals slightly adjusted to create surround-sound effects? if so, if i buy an amp for a RioCar, I'll need to amplify each speaker separately or something, won't I? do they sell amps that do that?
sigh... if only i were more knowledgeable in this area...
any help would be greatly appreciated.
Old Jan 7, 2002 | 07:04 AM
JustJeff's Avatar
Do you have the "Bose Upgrade" system?
Old Jan 7, 2002 | 08:29 AM
sTTanford's Avatar
Junior Member
yah
Old Jan 7, 2002 | 09:05 AM
JustJeff's Avatar
Default then you can do this...
<img src="http://people.mn.mediaone.net/ttbipes/jpgs/headunitwiring.jpg">
Look at the area here where you see the 'RF' - 'RR', where I have pointed to the "To Power Amp".
You can splice into these wires that plug into the back of the OEM head unit. The output of your head unit will then drive these signals to the "Bose" amp.
The amp should have the appropriate signals to drive all the speakers you have installed, and the controls on the new head unit should drive the appropriate fronts and rears.
Use this schematic to find the appropriate power signals on the OEM wiring loom.
Also, the output from your head unit to turn on the Bose amp.
Because the OEM connectors are on such short cables, you will have to do this while sitting in the car, up close and personal with your center dash. Drap a bunch of towels around when you do this also.
Good Luck
Old Jan 7, 2002 | 09:35 AM
sTTanford's Avatar
Junior Member
Default thanks!
the install looks a bit daunting (now that im back at school and have less time). might wait til this summer to upgrade the audio =)
thanks tho!
SKL
Jan 24, 2017 04:27 AM
Bezlar
31
May 13, 2006 12:22 AM
pat33
Jul 19, 2004 08:56 AM
pat33
Jul 19, 2004 07:30 AM
Nosaj
Feb 17, 2003 11:27 AM
