Pimps take note, a solid DIY post for a hot winter hookup - even for a jew! (picture intense)
I started with a second set of 6 spoke wheels that were in pretty good shape except for a couple scratches and one tire iron gouge. Thanks MisterP for that hookup!
I cleaned them well, removing as much dirt as I could. I then spent the next weeks sanding them until my hands hurt or I was tired of spending all day in the basement...this was the worst part of the process.
The sanded wheel
<img src="http://pictureposter.audiworld.com/6301/111-1185_img.jpg">
I left the middle part of the wheel unsanded.
<img src="http://pictureposter.audiworld.com/6301/111-1184_img.jpg">
I taped off the outside of the wheel
<img src="http://pictureposter.audiworld.com/6301/111-1187_img.jpg">
Some tape on the inside.
<img src="http://pictureposter.audiworld.com/6301/111-1190_img.jpg">
The paint I ordered from Germany. It had the most controlled and consistent nozzle for a disposable spray can ever! It is supposedly made for wheels and shouldn't chip. We'll see. I was going to get them professionally stripped and powdercoated but that was going to be a small fortune...this should work for a few years.
<img src="http://pictureposter.audiworld.com/6301/111-1193_img.jpg">
I only ended up using 2 and half cans and that's with 15 light coats! I also did not end up spraying clear as the black was glossy enough.
Me with my gear on before painting.
<img src="http://pubweb.nwu.edu/~rhf655/TT/112-1229_IMG.JPG">
The finished wheel
<img src="http://pictureposter.audiworld.com/6301/112-1207_img.jpg">
Repeat above steps to produce 4 pimp stealth wheels
<img src="http://pictureposter.audiworld.com/6301/112-1210_img.jpg">
I found a lady checking them out even before I could get them on the car...A real chick magnet.
<img src="http://pictureposter.audiworld.com/6301/112-1212_img.jpg">
This picture really shows the texture produced by the paint...subtle be definitely phatty.
I mounted the tires and put in the center caps. It started to snow just as I finished so I took the road warrior to a lot to do some celebration doughnuts.
<img src="http://pubweb.nwu.edu/~rhf655/TT/112-1224_IMG.JPG">
Also notice the ugly one wiper to complete my winter look.
<img src="http://pubweb.nwu.edu/~rhf655/TT/112-1226_IMG.JPG">
These pictures don't do my car justice. I'll have to clean it up and take some better ones soon but overall I'm very happy with the look. Now I just need to get the Audi roof rack to complete the winter getup. Anyone want to sell me one? :-)
Goals of the project:
Produce a phatty custom look that says winter warrior.
Have both a winter and summer setup that can clear stoptechs
Why did you wear a yarmulka to cover your head when painting? Or was this worn to show Joel? lol
Pop the hood, use a flat head to pop off the caps at the base of the wiper arms. Then use a 13mm to take of the lock nut. Then pull the arm off and reposition it up and put it back. The driver side arm was removed and I just reinstalled the same hardware. Does that help?
