How long should the stock brake pads last???
Should I wait till the 20k service instead?
Try a couple hard braking runs, it's probably just excess brake dust on the rotors causing the squeaks.
If not ,the pad depth is OK, and you are just experiencing "squeal" from various problems, like built-up crude that gums up the center channel in the middle of the pad, loose pad in the caliper, and general vibration problems from the pad ocsilating against the rotor.
It may be just simple 'squeal' that everyone seems to be experiencing lately.
Have you looked closely at the front rotor, to see if the pad is actually woren down?
Try that.
