Spacer Install - Will I also need to install the Kmac Kit
Old Mar 12, 2002 | 06:02 PM
Gator's Avatar
New Member
Default Spacer Install - Will I also need to install the Kmac Kit
Can anyone tell me what the Kmac kit actually does. I saw install pics on TTschwing's page but not sure how or why the fix camber.
Old Mar 12, 2002 | 06:08 PM
gesTTalt's Avatar
Default you'll probably need to install KMACs if you drop your car, I used only one set for the
lower arms, and sold the other half. You replace the bushing with the KMACs that have an acentric bolt that when rotated, bring the arm in or pushes it out. With the KMACs, my rears are at about -1.34. Some like to have a more aggressive camber, like Steve, @ -1.7.
Old Mar 12, 2002 | 06:10 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default When you lower.....
The suspension geometry changes (top of the wheels lean in increasing negative camber). If you're just adding spacers, it will only increase fractionally. Lowering is what exagerates the problem....
Old Mar 12, 2002 | 06:12 PM
Gator's Avatar
New Member
Default Re: you'll probably need to install KMACs if you drop your car, I used only one set for the
Thanks Gary. Where did you get the Kmac kit from.
Old Mar 12, 2002 | 06:16 PM
Gator's Avatar
New Member
Default Thanks, I will go that route
as I am going to use the H&R sport springs and Koni dampers.
Old Mar 12, 2002 | 06:18 PM
gesTTalt's Avatar
Default shox.com (ask for daryl and see if he'll give you the $249 price vs. $279)
you'll need to call them, don't know if they have the KMACs on their website yet
Old Mar 12, 2002 | 06:26 PM
Gator's Avatar
New Member
Thanks for the tip
ORL TT
May 25, 2007 02:59 PM
1 Mean TT
May 6, 2005 07:55 AM
Spiller-1
Aug 27, 2002 08:05 PM
RedBlackYellow
Mar 25, 2002 11:52 AM
JazziTT
24
Mar 1, 2002 12:04 PM
