Newly installed Nuespeed rear sway bar is squeeking.
Old Mar 14, 2002 | 06:29 AM
garreTTk's Avatar
Member
Default Newly installed Nuespeed rear sway bar is squeeking.
When installing I used all of the grease that was provided on both the inside and outside of the urethane bushings like the instructions said and felt that everything was sufficiently retightened.
Now when I go over larger bumps or speed bumps, the rear end squeaks. No noise except for when the suspension needs to travel.
Any hints or ideas on what to do to get rid of this sound?
Thanks - GarreTTk
Old Mar 14, 2002 | 06:56 AM
JazziTT's Avatar
Default I was positive my rear suspension was squeaking/groaning. I lubed the bushings
and any other part I could back there. It turned out to be the front sway bar was making the noise.
Dealer replaced it during my 20K service. Noise is gone. Same symptoms.. Large bumps and speed bumps would cause the noise.
Old Mar 14, 2002 | 07:09 AM
garreTTk's Avatar
Member
Default What type of lube did you use?
I want to use something that is compatible with the rubber and/or urethane parts.
Old Mar 14, 2002 | 07:17 AM
JazziTT's Avatar
Default It's a product from "Energy Suspension" It's really thick, gooey and sticky.
It won't wash away with water.. It's made just for suspension bushings.
Old Mar 14, 2002 | 07:21 AM
garreTTk's Avatar
Member
Default Is it this stuff?
<ul><li><a href="http://www.energysuspension.com/univ1.html">http://www.energysuspension.com/univ1.html</a</li></ul>
Old Mar 14, 2002 | 09:06 AM
JazziTT's Avatar
Exactly.. Good stuff.. got the big white container... Way more ecconomical
Old Mar 14, 2002 | 09:34 AM
Jason Chen's Avatar
Mine squeeked for about a month. I believe it needs to 'set'. No squeeks now
Old Mar 19, 2002 | 12:14 AM
DarTTChrisCLK's Avatar
New Member
Default Sorry, long time for post but if you read this, easy and cheap fix..
A buddy TT owner had the same prob. and sway bar you do. I helped him apply 10 wrappings on the bar around the area of the bushings with 1/2 in. teflon plumbers tape from a hardware store like home depot (costs about 50 cents)and noise is gone. It has been quite for 3 months.
 Pouria Savadkouei
 Michael S. Palmer
zarmstrong92
A6 (C7 Platform) Discussion
Jun 8, 2016 07:28 PM
fasTTback
10
Jul 6, 2006 11:31 AM
S4AVT
Jun 22, 2006 04:48 AM
esanmiguel
Feb 13, 2006 01:07 PM
Potomac2.7Tee
9
Jan 2, 2004 02:11 PM
