Question for all of you car experts:
How's that? I'm sure others can chime in on wet vs. dry sump systems.
The sacvange pump(s) work much like the saliva-sucker your dentist uses when drilling on your teeth; they vacuum up the oil mist in the crankcase and send it to a storage tank. It can then be pumped thru an oil cooler and then back to the engine bearings via the pressure pump.
Race systems may stack 3 or 4 pumps (1 pressure and multiple scavange pumps) on one shaft outside of the block and drive them with a timing belt.
As was said, biggest downside is cost. IMO, if you are racing and the rules permit dry sumps, that's the only way to go. Changing a street car from wet to dry sump doesn't gain much unless you are moving the engine down a few inches. Even 000 didn't do that, did he?
