Anyone ever have "sticky needles" on their fuel/temp guages?
Turns out that I replaced my factory black guage overlay with the silver guage faces. I noticed that after removing the 6 torx screws and the glass cover that the overlay actually fits very tightly, with no clearance up against the needles. This is only on the fuel/temp guages as the speed/tach have sufficient clearance. After removing the needles and replacing the overlay with the aftermarket silver face, I replaced the needles and found that they actually rubbed worse because of the very slight curve of the NEW aftermarket overlay. I pulled out the needles very slightly and checked the clearance between the face and the needle itself. Replaced the glass cover, and re-installed it into my vehicle.
No problems at all now, the needles always work right when the ignition is turned on.
It was re-assuring to find that this wasn't an electrical problem with the guage itself, but a case of the manufacturer in France, installing the needles too tightly. Im not sure if this is common knowledge here, or if others have had sticky needles, as I have never seen a post on it, but wanted to let everyone know that: If you have this issue, you can fix it yourself by removing the cluster, which took me no longer than an hour to remove and replace. I would have never fixed this had I not replaced my guage faces with the aftermarket faces. Saved me a complaint to the dealer though...
I am very hesitant to have the cluster replaced as I have heard that others on this forum's problems have only gotten worse. I can live with the little tap on top of the dash every now and then.
No problems since then though (with the instrument cluster, that is. I've had plenty of other problems.)
