NANCY- since you ordered the Rob Knob-just some advice for when you install it...
Old Mar 17, 2002 | 03:39 PM
TTough's Avatar
New Member
Default NANCY- since you ordered the Rob ****-just some advice for when you install it...
I am sure you will most likely do this anyway, but in case you do not....I made the mistake of installing the Rob **** and then placing in the shift pattern insert. After driving it quite a bit **** settled in a little deeper and I had to re-adjust it to keep the pattern lined up - it was a pain in the neck! I would recommend driving it without placing the insert in for a day ot two just to avoid the hassle that I went through. I am probably the only moron that this happened too!
Old Mar 17, 2002 | 03:42 PM
nansaidh's Avatar
Elder Member
thank you.... i'll do that
roadyTT
Nov 28, 2007 02:18 PM
DenverNoob
Jan 16, 2005 08:02 AM
Avantadrive
Mar 23, 2003 06:46 AM
wakko
Oct 19, 2002 11:22 AM
Kapoosh1
Sep 23, 2001 08:49 AM
