Passenger window relearn procedures?
Old Mar 18, 2002 | 08:30 AM
2002TTQC's Avatar
New Member
Default Passenger window relearn procedures?
My passenger window lost it's auto up/down feature and it no longer drops when the door is opened. Pete at Strat. said there is a way to reset it. Any help would be great so I dont have to visit the stealership. Thanks
Bruce
Old Mar 18, 2002 | 08:37 AM
GuilTTy's Avatar
Elder Member
Try holding the remote near the door than clicking "unlock" - then insert the key and turn the lock.
Duffer's Avatar
Member
Default These windows and linking electronics are sooo odd. When all goes FUBAR, then I
try everything.
Hold down the passenger window all the way for a few seconds, then back up, hold it a few secs
Second, hold both windows down for a few seconds and then go back up and hold a few secs
If that doesn't work, then I'll turn the car off and then on and see if all works.
Then I will do all the above and hope it works.
Last week, my up down one touch did not work, had it in the body shop where they evidently disconnected some things, and it all worked again.
Oh well.... if all else fails, dealer.
Old Mar 18, 2002 | 08:45 AM
Wennch's Avatar
Default Its in the manual but not clearly. I had this happen recently. You need to
click the switch on the door up which somehow resets it.
Old Mar 18, 2002 | 09:00 AM
ddkim2000's Avatar
New Member
Default no no.. this is the answer:
. If your windows do not drop and raise
when you open and shut the doors,or if the one touch does not work ,it's
because the dealer(like mine did) has not reset them.First raise the
window all the way up then release the switch then hold it up for 1-2
seconds ,this will reset it.
Old Mar 18, 2002 | 09:19 AM
2002TTQC's Avatar
New Member
Default Re: no no.. this is the answer:
Thanks I'll try that. I did lower and raise and held the sw. I'll try the lower/raise and release the switch then hold up for 2-3 seconds.
Bruce
Old Mar 18, 2002 | 09:24 AM
OTOF's Avatar
Elder Member
Default Here's the exact wording from
page 71 of the manual.
Close the window completely by lifting the power window switch and holding.
Release the switch and then lift it again for a second.
The convenience feature is now activated.
Old Mar 18, 2002 | 10:02 AM
GuilTTy's Avatar
Elder Member
Now that's exactly what I didn't say.
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 18, 2002 | 10:16 AM
ZGTT's Avatar
in other words RTFM? :-) (you are a lady Denbo)
Old Mar 18, 2002 | 10:28 AM
OTOF's Avatar
Elder Member
Moi, LOL, Just did a search to find my earlier posting of the info.. ;-)
RipGroove
TT (Mk2) Discussion
9
Dec 19, 2017 08:42 AM
ESFO
Aug 12, 2005 09:02 AM
Stinky J. Sock
9
Apr 8, 2003 07:57 AM
TTschwing
Feb 6, 2001 10:17 AM
