Neuspeed rear sway bars.... Too much oversteer....need your opinion.
Old Mar 18, 2002 | 09:11 AM
Jason Chen's Avatar
Default Neuspeed rear sway bars.... Too much oversteer....need your opinion.
I seriously think my car has a bit too much oversteer. Its not excessive, but its borderline. It does make the care more neutral, but I actually like it when it pushes a little bit more. I don't think I'm at that level that can handle this much oversteer. So here is my options.....
Option 1- take the rear sways off and put stock back on.
Option 2- put neuspeed's 22mm front sway bars on
Option 3- put neuspeed's 25mm front sway bars on
Thanks. Oh yeah, I have MK1.
Old Mar 18, 2002 | 09:23 AM
mtbracr1's Avatar
Junior Member
I have the 22mm front and the rear and it handles very nicely.
joe@vwvortex's Avatar
Default Take off the rear bar OR put on the 22 front bar - don't need anything more
however - i'd just dump the rear bar.
Old Mar 18, 2002 | 09:24 AM
JazziTT's Avatar
Default Remember the front sway bar swap involves dropping the subframe and using those "single use only"
bolts when re-installing. It's a pretty major effort.
Old Mar 18, 2002 | 09:25 AM
Jason Chen's Avatar
Doesn't look too bad of a job. I have to lower the car anyways, I might as well do it then
Old Mar 18, 2002 | 09:31 AM
TTerrell's Avatar
Junior Member
Default dito
or get used to the oversteer... Not such a bad quality for AWD unless it's excessive...
Old Mar 18, 2002 | 09:44 AM
jop's Avatar
jop
New Member
Default If you end up swapping the front swaybar and want to sell the old one...
... e-mail me. I'm interested in buying one of these if the price is reasonable (or would trade for my Mk2 bar). I think the Mk1 is 1mm smaller (softer) than the Mk2, right? I'm just interested in dialing out a bit of the Mk2 understeer while having the option to remain in Solo2 stock for now (don't mind a little extra body roll).
Old Mar 18, 2002 | 10:01 AM
ross@downforce.net's Avatar
Member
or - change your tire pressures...
 Pouria Savadkouei
 Michael S. Palmer
Old Mar 18, 2002 | 10:11 AM
Larrytt's Avatar
Elder Member
send me an e-mail, I have a few MkI swaybars I can sell you one.
Old Mar 18, 2002 | 10:15 AM
djwhiTTe's Avatar
New Member
Default you might want to read this thread
its very informative<ul><li><a href="https://forums.audiworld.com/tt/msgs/258643.phtml">thread</a></li></ul>
