Clutch questions
Old Mar 18, 2002 | 10:19 AM
TTBOITOY's Avatar
New Member
Default Clutch questions
Hi.
How long does the average clutch last (assuming 0 riding on it, minimal downshifting, city driving conditions, and no bad or grinding shifts)? What are signs it is going to die?
Should I have it replaced if my warrantee is about to expire just to be safe?
Thanks.
Old Mar 18, 2002 | 10:25 AM
GuilTTy's Avatar
Elder Member
They won't replace it under warranty unless it is actually failing.
Old Mar 18, 2002 | 10:41 AM
ddkim2000's Avatar
New Member
Default Clutch can go 100K+.. or as little as 20K miles
depending on how hard you drive the car. if you do alot of redline drops,,,, then anything goes.
when your clutch is done,,, you'll feel the car slipping. meaning engine will rev but car won't move as quick as you normally expect, car will feel like its in neutral while accelerating.
Old Mar 18, 2002 | 10:46 AM
TTBOITOY's Avatar
New Member
How much does a new one cost for a TT?
Old Mar 18, 2002 | 10:53 AM
ddkim2000's Avatar
New Member
Default have no idea. how many miles do you have?
the way you describe your driving. I don't think you'll be needing a clutch for a while. unless you are racing the TT on weekends on a track.
Old Mar 18, 2002 | 10:55 AM
TTBOITOY's Avatar
New Member
40K
Old Mar 18, 2002 | 11:00 AM
ddkim2000's Avatar
New Member
I wouldn't worry.... besides warranty don't cover normal wear and tear
coasTTal
Feb 13, 2006 07:18 PM
CoochasTT
Jul 19, 2005 04:20 PM
SparTTan
Mar 6, 2002 08:25 AM
