225 intake manifold: Real answers! No more BS! :)
Old Mar 18, 2002 | 01:23 PM
Jason Chen's Avatar
Default 225 intake manifold: Real answers! No more BS! :)
OK, the 225 intake manifold WILL fit on the 180. Thats right folks, direct fit! Thats right! No fuel lines to move, no fuel rails to replace. Bolts right on! You do have to cut some wrapping under the stock 180(which supposely have a bit more wraping than the 225)
Well, what does that mean to you? It means you will have LESS piping than if you went back under the engine bay. Less piping, less pressure drop.
So for those who said it can't be done, it can. Want proof? Here is a picture of the ECS dual intercooler setup for the GOLF 1.8T.<img src="http://www.ecstuning.com/vwpartsfolder/18t%20esrintercooler%201.JPG"> If you look carefully, that is a 225 intake manifold with Eurospec engraved on there.
Want more proof? Call ECS tuning at (800) 924-5172 and ask for Tom. He had his share of people asking him the same exact question.
As for me, I'm going to buy a 225 intake manifold and a intercooler off of a semi truck(i'm serious). And custom the 2 tiny pipes that I need to get it to work. Wish me luck. Maybe I'll make a kit for us 180s to buy if there is enough interest
Old Mar 18, 2002 | 02:16 PM
hoTTub's Avatar
Member
Default please dont say that I said it could not be done, I simply said that
the fuel, vacuum and other various lines would have to be moved and or replaced.
Have you checked into whether the throttle bodies are a correct port match?
The fuel rail may be OK as well as the supply lines.
The brake booster is no way going to work.
Good luck Jason and let us know!
Old Mar 18, 2002 | 02:30 PM
Jason Chen's Avatar
Default Wrong.......
<i>the fuel, vacuum and other various lines would have to be moved and or replaced.
The brake booster is no way going to work. </i>
No Sean, it bolts right on. You said that these things need to be done and it will cost more int he long run. There is some cutting needed to get the wrapping off the 180, but thats it. Who was the one that told you it need those things? Give ECS a call. They will tell you what is the correct info.
Now keep in mind this is JUST for bolting on the intake manifold and not everything the 225 has(like the top visable pipe or anything else). Just the 225 manifold.
A FMIC is possible using less piping, Sean.
Old Mar 18, 2002 | 02:46 PM
hoTTub's Avatar
Member
Default I know a FMIC is possible with less piping if you can get the
Intake to the other side, I see how it works with the 225.
I am simply saying that no amount of *unwrapping* is going to make the brake booster hose in the right position. So maybe that is the only part that needs replacing.
No one has ever told me that it could not be done, this is based on what I looked at. Calling ECS Tuning doesn't really help me either, while I think these guys have some cool stuff, I really dont know of them so who knows?
Please let us know how it works out, this would be great if it is not that expensive.
also, you said the throttle body is the same? I thought they were enlarged for the bigger manifold no? Anyone know?
Old Mar 18, 2002 | 02:49 PM
Jason Chen's Avatar
I'll let everyone know soon
Old Mar 18, 2002 | 03:28 PM
RichP's Avatar
Junior Member
Default I though someone said awhile ago this kit would NOT fit on the TT180...
J have you spoke to them yourself?
There are also 2 companies with upgraded SMIC which look to be good alternatives pricewise (around $550) Forge is one, and I think Forced Performance is the other.
Old Mar 19, 2002 | 12:55 AM
Jason Chen's Avatar
Default Spoken to them myself. This kit does not work for our car. I'm just talking about the 225 intake
manifold and its ability to bolt right on.
Old Mar 19, 2002 | 07:39 AM
RichP's Avatar
Junior Member
Default Isn't the 225 Thottle body bigger? I remember way back in theday when Mance(who remembers him) was
getting all the info on converting a 180 to 225 parts and I though he said the 225 throttle body and intake ports were bigger. I think he actually ordered a bunch of 225 stuff from Clairparts and took measurements.
J, I'm not trying to discourage you, just trying to let u know it may not be a simple bolt on.
I think u may also have to extend some of the wires.
 Pouria Savadkouei
 Michael S. Palmer
carsluTT
Mar 27, 2005 07:54 AM
fredfromny
Nov 20, 2004 06:09 AM
RedRoadster
Jan 13, 2004 01:59 PM
Alf Garnett
Apr 17, 2002 03:24 PM
VAP
Jun 8, 2000 03:28 PM
