How hard is it to aim a Xenon headlight?
just be careful when you pull the hex out as they ahve a tendency to get stuck in the malleable plastic socket-head adjuster ***** and pull the ***** out.
replacing the bulbs (in reponse to your post above) might be too difficult to do with the headlights still attached to the car. which would require removing the front fascia (the whole front end) to accomplish. removing the fascia probably takes a good hour~1.5 hours on and off, but might take 2 horus the first time (remember to clamp the alien hoses and deattach them before taking the front off).
splitting open the headlights to remove the side reflector probably takes an hour total. but getting them painted at a body shop will put your car out of commission for a good day.
You told me what I would have to do about removing reflector, but what would have to be taken apart on the headlight to replace the bulbs?
<img src="http://pictureposter.audiworld.com/24809/16_-_finished_lf.jpg">
<A HREF="http://www.stanford.edu/~kenhorne/files/asdfasdf/IMG_0318.JPG">high res front view</A>
